This is a bit of a strange request. I was installing the Mopar heavy duty splash guards (front = 82216217AA, rear = 82216216AA) on my 2021 Limited and the plunger on two of the plastic pop rivets broke in such a way that rivet isn't holding. 0C must have been too cold to set them.
These seem to be specialized rivets as I've been searching for a couple of days now and can't find anything similar. What makes them unique is their grip range is quite large as they pass through a heavy washer, a thick splash guard, the wheel well liner and then a fender panel. I found a picture of a similar parts kit and have highlighted the area of the rivet that makes it so hard to find. Even this picture was difficult to find and I lucked upon it on Amazon.
It's a M6.3 rivet with a body length of around 35mm. The section that I've highlighted is probably 10+mm long. I've tried typical M6.3 rivets that have a much shorter fixed section and they just don't work in this application.
Of course the parts department at the dealer can't find anything unless you give them a part number.
Any help locating these would be greatly appreciated.
