1 - 9 of 9 Posts
· Registered
Anyone ever hear of these folks? Looks like a decent replacement with whole housing. My fog lights have the dreaded "jiggling".
· Registered
Don't know anything but I do see that the Overview details shows they fit 2001-2008 contrary to what the description says. If you are going to order them be sure to check that the part numbers do really match what suits your truck.
· Administrator
You have to order two pairs, at least you'll have spares if they stop working. I did see where is mentioned anything about being CANbus compatible, you will probably need to get a set of Anti-Flicker modules so the LED fog lights will work. These will work for whatever LED or 35w HID you install: CANBUS Anti-Flicker Module (pair)
You can also use AlfaOBD to enable the fogs for LED and disable the high beam drop out.
I replaced my fog lights with the Morimoto XB LED projector fogs. They keep all the light below the fog light height. Dodge Ram Vertical: Morimoto XB LED Fogs - Complete Housings from The Retrofit Source (can be found at other stores cheaper).
· Registered
Good call there. Devil's in the details.
I want something that replaces the whole housing since I have the fog light jiggle unless I torque down the adjustment nut, but if I do then they basically aim to far down to be if any use.
· Administrator
Even though I have the Morimotos now, I have thought about switching to a set of Rigid SAE fog lights. The Rigids are pricey but the beam pattern is awesome and they're probably some of the best on the market.
The problem with putting LEDs in the reflector housing fogs is they scatter too much light and become blinding when you need them as fog lights.
· Registered
I installed Baja Designs cubes. Very satisfied.
85574
85576
85577
1 - 9 of 9 Posts
