21 - 34 of 34 Posts
Discussion Starter · #21 ·
If the speedometer is not correct, that affects several things. Timing of shifts, fuel mileage being the main 2. My '16 with 4" lift and 35x12.50 tires dropped from 24-26 to 19. Recalibrated speedo and it came back to 20-22. Use a GPS speedo on phone to check speedo accuracy.
I checked speed using gps and found 2 mph difference, is this a considerable drift that will require calibration ?
2015 Trademan 4x4, 3.92, 6.4' bed air lift 1000 bags, bilstien shocks, 34" nitto g2s, Unknown tune.
So the speed will be off different amounts depending on the speed it's not a consistent amount.
What size tires does the truck have now? Did the dealer install those tires? They may have attempted to adjust the size already.
I've never owned a vehicle or motorcycle that was withing 1% in 50 years 🤔. More like 2 to 3% in my experience
I think the point was if it's off by 2mph at 20 it's off by more at highway speeds and that makes a real difference.
I have a stock 21 Rebel w/3.92. My best highway only mileage is 29 and normally will average 26 - 27 mpg. These results are at highway speeds of 55 - 65 mph. On the interstate at speeds of 70 mph plus, my mileage will average 24 - 26 mpg.
You haven't told us which way the speedo was off, as well as what speed you checked it at.
Reactions: CraigGuy
Discussion Starter · #31 ·
[QUOTE="SlowRoller"
Depends 2 mph off at 25 or at 80? Its best to get the speedo within 1% accuracy so at 100 mph that would be a 1 mph variance.
[/QUOTE]
Truck is under reporting speed, below is a summary. I read that speedometer error tolerance can be up to 10% but should overreport speed and should never under-report.
Dash SpeedGPS speedError %
40437.5
50548
60658.3
70768.6
40437.5
50548
60658.3
70768.6
That sounds like speedometer was not reset for the larger tires. You could calculate if the error matches the tire size difference:
Speedometer Calibration (tiresize.com)
Your MPG on the EVIC is off by about 8% plus the usual error.
Discussion Starter · #34 ·
Thanks. I'll ask the dealership to get it calibrated. MPG actually improved to 19.5-20.5 after filling from a different gas station. With the 8% difference that would make it 21-22 which makes sense in comparison to original MPG with stock tires.
21 - 34 of 34 Posts
