1 - 5 of 5 Posts
So here is my fully loaded 2015 Eco Laramie with the following upgrades.......
Falken Wildpeak AT3W 295/60 r20
2" BORA Wheel Adapters
Bilstein 6112 kit in front ( 9th notch )
SuspensionMAXX Front sway bar end links SMX-1300L
Bilstein 5100 with Eibach springs in rear
Timbren SES DR1500DQ for level load
Hellwig 7883 Sway bar kit for lifted trucks (Longer end links)
SPOHN Performance Red Panhard Bar w/poly bushings D09-1500-101
G2 Differential Cover 40-2028ALB
Prime Choice PR63008LR/007LR Performance Drilled/Slotted Brake Rotors
Power Stop Z36 Brake Pads Z36-1084
Rough Country Red Brake Caliper Covers 71130
Bushwacker 14064 Trail Armor Rocker Panel / Sill Plate Cover
AVS low profile in channel rain visors
Stubby Rubber Antenna
DeeZee tail gate assist
HID Low beam / LED high beam headlight bulbs
LED Fogs
LED replacement on all other exterior lighting
CFT polished round intake tube
CFT polished turbo baffle tube
CFT Stage 1 EGR Delete kit
CFT AGS Delete
AFE Magnum FLOW Pro DRY S Air Filter
SFT Tuned ECU and TCM
Somewhat debadged with b-pillar vinyl removed.
Honest opinions would be much appreciated......
CHEERS!
20190812_102923.jpg 20190812_103025.jpg 20190812_103046.jpg 20190812_103103.jpg View attachment 81746 View attachment 81746 View attachment 81748 20190812_103216.jpg 20190812_103229.jpg 20190812_103249.jpg
Looks decent with all those additions. Now you need to paint it creatively so it is not just the color of the road. Some color shading and graphics could really set it apart.
1 - 5 of 5 Posts
