Shouldn't this have been covered under the recall?
Greetings TexasRam,Unfortunately the current recall is just a software update to allow the truck to continue to run in limp mode by using the camshaft timing instead of crankshaft. I have kept my receipt in case sometime in the future RAM decides to create a recall that will cover the part replacement instead of just a software update to keep the truck from dying when the part does fail.
I can confirm if you've had the recall #W58 performed you are able to restart multiple times while in limp mode caused by tone wheel failure. However, it takes longer, 3-4 seconds of cranking before the engine will start.
Message sent! It’d be great if this out of pocket repair was covered under the recall.Greetings TexasRam,
Can you send us a message with your VIN and dealer info? We would like to look into this for you.
Rob
Ram Cares
What was the B date of your truck ?Interesting. I would have bought an EGR cooler delete kit and not have had to buy another tune. That said it would have done nothing for the reluctor wheel. When my reluctor wheel failed I checked but my particular engine was not included in the recall so I was not able to get my repair costs reimbursed.
I was referring to the birth date of the truck. It should be on the sticker by the drivers door or b pillar. I have a Grand C so I'm not familiar where it is on the trucks. I also was assuming you were talking about your original engine but maybe not ?Where do I find the B date? Is that truck or motor related. I presume motor and the white stickers?
Hi, we responded to your DM, please take some time to review it and get back with us at your earliest convenience.Message sent! It’d be great if this out of pocket repair was covered under the recall.
Can you tell me (us?) why if you didn't get the AEM update, you get a reluctor wheel replacement but if you did get the update, all you get is a firmware/flash update? It seems like you'd want to replace the bad parts for everyone. I know at the end of the day it's probably about the cost to replace the reluctor wheels but it seems strange to me.Hi, we responded to your DM, please take some time to review it and get back with us at your earliest convenience.
Rob
Ram Cares
There's no software update available for the non-AEM trucks. Those trucks are not EPA compliant so FCA cannot update the software. This is why they get a new part. AEM trucks get the software update to keep the truck running in the event of a tone ring failure. If the ring fails, FCA will likely cover it under the AEM extended warranty.Can you tell me (us?) why if you didn't get the AEM update, you get a reluctor wheel replacement but if you did get the update, all you get is a firmware/flash update? It seems like you'd want to replace the bad parts for everyone. I know at the end of the day it's probably about the cost to replace the reluctor wheels but it seems strange to me.
The recall covers only the sensor, not the wheel. Been there, done that. Ours required 18 days in the shop because we had other issues (radio amp and heated seats) that required attention.Shouldn't this have been covered under the recall?
Good idea. A a former aircraft mechanic we replaced components based on hours of use. No pull off lanes in the sky. No way of telling if or when it will fail.I'd just as well pay for a new reluctor wheel and labor to avoid the hassles of being stranded or worse yet, harmed. Is the part available?
From what I've read its about a days labor to remove transfer case and transmission. Replace the part and then reinstall.
