1 - 3 of 3 Posts
Vendor
The more attention your vehicle attracts on the road, the safer you are. If you want to enhance your truck’s appearance without spending a small fortune while also improving its functionality, you might be interested in a new universal LED tailgate light bar from Lumen. It features three rows of ember, white, and red LEDs providing turn signals and hazards, reverse light, and running lights and stop signal doubling your tail lights. The accessory is available in 48-inch and 60-inch lengths featuring 1000 and 1200 energy-efficient LEDs respectively.
The most prominent feature of this dazzling light bar is sequential three-stage turn and hazard signals. They will inevitably catch the eye of the most distracted drivers on the road. The accessory has a sturdy aluminum housing which is waterproof and resists vibrations well. The plug-and-play installation is very simple. The bar is installed using strong 3M double-sided adhesive tape. You can plug the flat 4-pin connector directly into your truck’s trailer wiring harness, buy an adapter if your vehicle has a 7-pin round connector, or tap directly into the tail light wiring with provided pigtail.
Lumen® - LED Tailgate Light Bar
Specifications:
Number of LEDs: 48” light bar – 1000, 60” light bar - 1200
Housing material: aluminum
Can be cut: no
Plug: 4-pin flat connector
Warranty: 1 year
Features:
Dazzling LED Sequential Turn Signal Display
Super Bright Reverse Lights
Weatherproof construction for reliable operation (IP67 ingress protection rating)
Dependable operation in any weather conditions (Working temperature range: -20°F to 170°F)
Easy Plug-and-Play Installation
If you have any questions, feel free to ask them in replies or in private messages.
Also, you can contact our technical experts in Live Chat at CARiD.com or simply call 800-505-3274 (tall free).​
Vendor
Today we are back with a new video, dedicated to its installation. Our tech expert Greg will guide you through each step, with all the tools needed and detailed explanation of the whole process.
Finish off the look of your truck and make it safer with Lumen LED Tailgate Light Bar!​
1 - 3 of 3 Posts
