1 - 10 of 10 Posts
What do you guys think of this wheel? It's a new wheel from Method for 2014.
I think it has a simple/tough looking design. I'm not sure about all of the chrome bolts surrounding the wheel. Do you think that's to much?
Thoughts?
The bolts are a simulated bead lock. I like the look, assuming it's for drag racing, or off-road.
Personally... I think black wheels look bad though.
I like it. I am lifting mine 6 inches when lifts become available for the diesel. I will put some nice wheels on too. I am torn between wheels if ill go Black or Chrome. Chrome I like better I think.. I like the black too. it has been growing on me!!
Do they come in 17"?
They are also available with a machined face. The weight of the wheels don't seem that bad either.
17x8.5 - 27.5 lbs
18x9 - ?
20x9 - 34 lbs
I picked up Method Standard for mine (17x8.5 0 offset) in the standard machine finish (not just the face, the whole wheel). They are a fairly simple design such as these. Method makes some good looking wheels. The simulated beadlock look isn't cheap, they are real SS bolts. None of that plastic crap.
They're cast, not forged, so sure I could probably have some lighter wheels but they would have cost a lot more.
These wheels with some LT285/75R17E A/T are going to weigh very close to, but slightly heavier than my 20x9 WRF wheels with stock SRA tires.
They're going to weigh a hell of a lot less than my original plans for the truck, which were the WRF wheels with some LT285/65R20E A/T tires. Those stock 20x9 are HEAVY.
So depending what wheels you're coming from, you might not be all that bad on weight.
Reactions: olbedhead
I'm not a fan of fake parts - ie bead locks or things that make turbo sounds despite not having a turbo.
personally i'm a brushed aluminum/chrome fan myself.
1 - 10 of 10 Posts
