The Valvoline doesn’t list 12991 in their marketing, nor does Shell list it in the Helix ultra marketing, in spite of the fact it should be the same as the Pennzoil.
I removed both of those for now. Shell confirmed that none of their products met spec.The Valvoline doesn’t list 12991 in their marketing, nor does Shell list it in the Helix ultra marketing, in spite of the fact it should be the same as the Pennzoil.
This is specifically for the Gen 3 engine.Is this only for the 2020 engine?
are have the specs been upgraded (???) for the earlier engines as well
thanks
The Valvoline MST 5W-40 was listed to meet MS-12991, but I can't remember where I found it. I don't want to put out misinformation, though. But if MS-12991 is printed on the bottle, that is enough for me to put it back on the list.Interestingly, had an owner post a picture of the Valvoline bottle in a Facebook group - it says MS-12991 on the bottle - it’s VALVOLINE Advanced Full Synthetic MST 5W-40. It, however, lists ACEA C3. Which has me confused, as it should have to be A3/B4 to meet the spec. I’m really not sure with that one!
It is! I have pictures! Just find it odd, that the website doesn’t even have a PI sheet showing that!The Valvoline MST 5W-40 was listed to meet MS-12991, but I can't remember where I found it. I don't want to put out misinformation, though. But if MS-12991 is printed on the bottle, that is enough for me to put it back on the list.
Since it's stamped on the bottle, that's what I went with. I'm also going to keep a couple of the empty bottles on the shelf in my garage in case the dealership tries to give me any issues later down the road.The Valvoline MST 5W-40 was listed to meet MS-12991, but I can't remember where I found it. I don't want to put out misinformation, though. But if MS-12991 is printed on the bottle, that is enough for me to put it back on the list.
Does Ram sell it in a Mopar bottle or does it only come in the Pennzoil bottle? If it comes in the Mopar bottle, then we need to add the Mopar part # for the oil.I can pull the number. It’s Pennzoil Platinum Euro 5w40.
68231020AADoes Ram sell it in a Mopar bottle or does it only come in the Pennzoil bottle? If it comes in the Mopar bottle, then we need to add the Mopar part # for the oil.
If it has a Mopar part #, then it should come in a Mopar bottle.68231020AA
Not sure what bottle it shows up in!
The SRT oil comes in Pennzoil 6 qt boxes!
case of 6 for 50.17 on amazonDoes Ram sell it in a Mopar bottle or does it only come in the Pennzoil bottle? If it comes in the Mopar bottle, then we need to add the Mopar part # for the oil.
So the 3rd gen EcoDiesel is running oil designed for spark ignition verses compression ignition as indicated by the API SN in your post??The new 3rd gen (2020+) EcoDiesel has different specs than the 2nd generation (2014 - 2019) engine. The following oils meet the new MS-12991 and API SN Certification/Standard/Approval.
I initially thought the same - and phrased it similarly - the oil companies have made clear that these oils are specifically designed for light duty automobiles, including diesels. It’s optimized for the issues incurred with smaller engines, as opposed to the HD class oils that meet API C class and ACEA E class specifications, which are optimized for use in OTR trucks, and effectively have to prioritize different aspects of the performance due to their use cycle.So the 3rd gen EcoDiesel is running oil designed for spark ignition verses compression ignition as indicated by the API SN in your post??
Interesting. Any idea what issues they are referring to when comparing large OTR trucks verses smaller light duty diesels? I’m not sure I would lump light duty diesel in with spark ignition oils. Are the additive packages for SN oils that they can handle the added acidity and soot from diesels?I initially thought the same - and phrased it similarly - the oil companies have made clear that these oils are specifically designed for light duty automobiles, including diesels. It’s optimized for the issues incurred with smaller engines, as opposed to the HD class oils that meet API C class and ACEA E class specifications, which are optimized for use in OTR trucks, and effectively have to prioritize different aspects of the performance due to their use cycle.
In fact, the majority of these oils were specifically developed for use in Renault, Volkswagen, Mercedes, and PSA diesels, and the specifications they have OE approvals for indicates that!
Again, more that the majority of the oils were developed as low/mid-SAPS diesel oils for small euro diesels. Some of the differences include the OTR trucks being concerned with scuffing resistance that simply isn’t as critical on the small diesels. Most small diesels have aluminum pistons, where OTR diesels often use Steel - so the wrist pin compatibility and lubricity characteristics are different. OTR oils have different HTHS needs, due to the size of the components, and the clearances and ring tensions used.Interesting. Any idea what issues they are referring to when comparing large OTR trucks verses smaller light duty diesels? I’m not sure I would lump light duty diesel in with spark ignition oils. Are the additive packages for SN oils that they can handle the added acidity and soot from diesels?
I wonder if this is an emissions deal? Sure the manufacturers approve, but that doesn’t necessarily mean it’s the best for the engine (just look at the EGR).
