Awesome! I just added you to the High Mileage Thread. Feel free to subscribe to that thread for future updates. It's located here -----> (39) 50,000 - 500,000 Mile Club | RAM 1500 Diesel Forum127,206
These engines seem to use a lot of oil, which very well could be impacting ash accumulation in the DPF. How often are you changing the oil? Are you having to add oil in-between oil changes?Truck still runs and drives like new but after 100,000 miles it did start going into active regenerations every 700 miles so that concerns me that the DPF is not going to last a whole lot longer
I’ve never had to add any oil between changes. May have to do with running T6 for so long. I didn’t go away from it till 90 or 100k.These engines seem to use a lot of oil, which very well could be impacting ash accumulation in the DPF. How often are you changing the oil? Are you having to add oil in-between oil changes?
I have been an Amsoil user for 30 years and have used their dual filter remote system on everything I own. But, they don’t make an adapter for the ecodiesel. I had to make an adapter that takes the place of the factory oil filter and oil filter cap. The adapter is made out of 6061 aluminum and takes the place to the original filter and cap. One of the Amsoil filters is a full flow and the other is a bypass filter that filters down to 2 microns. I had around 3000 miles on the oil when I got the system installed. I now have a little over 7000 miles on the oil. At 10k I’ll change the oil and filters and send in a sample to be analyzed. I can tell that the oil isn’t black anymore.Updated on 6/06/2022
Recommendation: Do NOT rely solely on this list. Always double check to make sure the following oils are current in meeting factory specifications.
The new 3rd gen (2020+) EcoDiesel has different specs than the 2nd generation (2014 - 2019) engine. The following oils have been known to meet the new MS-12991 and API SN Certification/Standard/Approval. I put them in order based on what I think are more 'commonly known', not based on preference or performance.
I will update this thread as new approved oils are added and when existing approved oils no longer meet approval. So far, I had to remove Valvoline and Liqui Moly even though both met spec at one point in time.
Mopar 68524020AA 5W-40 replaces 68231020AA
Pennzoil Platinum Euro 5W-40
FRAM Full Synthetic Euro 5W-40
Quaker State Ultimate Durability EURO 5W-40
Havoline ProDS 5W-40
Redline Full Synthetic 5W-40
Motul 8100 C-clean 5W-40
Motul 8100 X-cess 5W-40
Motul 8100 X-cess gen2 5W-40
TRIAX Euro LX 5W-40
TRIAX Euro Ultra VX 5W-40
Ravenol VST 5W-40
Total Quartz 9000 5W-40
ELF Evolution 900 SXR 5W-40
ELF Evolution 900 FT 5W-40
AMALIE Elixir Full Synthetic Euro 5W-40
Millers Oil Trident Fully Synthetic 5W-40
Millers Oils XF LONGLIFE 5W-40
MPT Thirty-K True Synthetic High Performance 5W-40
CAM2 Blue Blood Elite Euro 5W-40
FUCHS TITAN Supersyn SAE 5W-40
Lubrication Engineers 5w40 Monolec Ultra Syn Heavy Duty Engine Oil
REPSOL ELITE COSMOS HIGH PERFORMANCE 5W-40
The following manufacturers have given a verbal/written approval, but they have not and/or will not update the literature to reflect it.
Amsoil 5W-40 FS Synthetic European (EFM)
Liqui Moly Leichtlauf High Tech 5W-40
MS-11106 is a 5W-30 LS Euro oil.I'm surprised they did the same BS with the new trucks that they did with the first '14+ with MS-11106 then decided that CJ4 oil was the 'right' oil to use later on.
Is that the same as the Quaker State Ultimate Durability EURO 5W-40? looks like a different product?Walmart carries the Quaker State Euro 5w40, i think it's $23 for a 5L jug.
This is the one you want. It will have the MS-12991 spec on the back.Is that the same as the Quaker State Ultimate Durability EURO 5W-40? looks like a different product?
Hey any updates on this adapter? was also wondering if after installation you had any drop in EOTs. definitely a more thorough filter element that the factory.I have been an Amsoil user for 30 years and have used their dual filter remote system on everything I own. But, they don’t make an adapter for the ecodiesel. I had to make an adapter that takes the place of the factory oil filter and oil filter cap. The adapter is made out of 6061 aluminum and takes the place to the original filter and cap. One of the Amsoil filters is a full flow and the other is a bypass filter that filters down to 2 microns. I had around 3000 miles on the oil when I got the system installed. I now have a little over 7000 miles on the oil. At 10k I’ll change the oil and filters and send in a sample to be analyzed. I can tell that the oil isn’t black anymore.
i View attachment 92435 View attachment 92436 View attachment 92437
Order on line from walmart....$25 per 5 qt container. Leaked in the box so just had enough for the oil change. Lost three qts in shipping....poor UPS truck.So, the meets the MS12991 spec....will pick some up for my first oil change! Thanks for your help.
That sucks. I usually go in and buy my oil off the shelf, or I have them pull it and waiting for me. Having bought oil online for my other vehicles has taught me to avoid having liquid shipped if at all possible.Order on line from walmart....$25 per 5 qt container. Leaked in the box so just had enough for the oil change. Lost three qts in shipping....poor UPS truck.
