461 - 480 of 509 Posts
Can anyone confirm that this app and the obd reader will work on 2018 trucks? Will I need one of those patches that gets through FCAs anti tamper firewall?
I purchased a VGATE and I am trying to use the Torque Pro app on my Galaxy. I am unable to get any gauges to register. Where would you start?
Is Galaxy paired to the VGATE? Torque should automatically connect to the VGATE. There is a setting in Torque to make that OBD dongle the default. Another thing is check in the vehicle profile that the comm is set for: ISO 15765-4 (CAN 11bit/500k baud)
Got it. Thanks. I have it reading all the basic gauges. I am not seeing the options for Boost, DPF Capacity, Regen Time, Regen Distance. Any other gauges people recommend?
Probably the ones to watch is the EGT1B1, EGTB1S3 and Boost gauges while towing. I also have the CAC temp, Fuel Rail Pressure, and DPF soot %
Some of those gauges are custom PIDs which can be found earlier in this thread.
If you like to know when you truck is in an active Regen, the EGTB1S3 will be at or above 1000°F
" regen dstance " worked until late 2015 ,
then after some new software flash from RAM, it stopped working on all the monitors I know of ,
so don't spend the whole day researching that particular PID .
I don't use Torque but I like the images of possible configuration "" themes "" others posted .
Edit : seems a bunch of you guys got it working on Torque Pro app " Attaboy " .
posts that give description of fancy name to get desired Pids
are discussed in posts :
27 , **35 , 37 , 38 , 43 , 49 , 66 , 89 , ( 103 + 104 ) ,
110 , 118 , ( * 152 ) , ( 187 to 199 EGR active Pid ) ,
( regen distance 219) , (in post # 222 uncle buck seems to have figured out the regen distance )
277 , 280 , ** 316 , 351 , 363 ,
<<< in post # 371 , member dub posted a dropbox adress , with the look of his theme , nice .
( dropbox.com/s/qvp3rg1uiwvyks0/torque.zip?dl=0 )
posts 378 and 379 and 381 ; useful added info for this >>>
another set-up shared in post # 419 , 421 , 442 , 449 , 452 ,
86885
86886
86887
86888
I found a Regen Distance that seems to be working on my truck. At least it is giving a reading. Look forward to the feedback.
018B
DPF Average Distance
DPF Avd
0
65535
1x
Miles
(F*256)+g
* 2018 *
security bypass cable for 2018 and newer trucks : (( seems like the 2020 does not need it ???))
you will need security gateway bypass cable. This place makes really good harnesses:
Security Module Bypass | KaodTech
86889
2015 Laramie 2WD
018B
DPF Avd
0
65535
1x
Miles
(F*256)+g
Those are the same settings I have and they seem to work for me, also.
I've been playing with Torque Pro Ver 1.10.114 on my Android Phone with the VEEPEAK V1.5 (BLUE) OBDII USB Adapter.
I am trying to locate the latest released Documents for SAE J1979DA-201905*.xlsx (filename may have additional characters
in place of the "*". That document is the latest information according to the Internet. Or is there any other Document that can
be located for the RAM 1500 Eco-Diesel's? Anyone have access to the PDF?
I've used Torque to get the Bits from Blocks 0x00, 0x20, 0x40, 0x60,& 0x80 that show which PID's are available for access.
Blocks 0xC0, 0xE0 are not accessed for PID's.
I created a Gauge on Torque, got it working from extra PID's in Chrysler, and then exported that gauge's file to get the format for all PID's.
My exported PID's for Block 0x00 are:
Code:
"Name", "ShortName", "ModeAndPID", "Equation", "Min Value", "Max Value", "Units", "Header", "startDiagnostic", "stopDiagnostic", "Scale"
"TEST: Run Time2","Run Tm2","0x011F","((A*256)+B)/60",0,6000,"Mins","Auto","","",1
"TEST: P00a","P00a","0x0100","INT(A) & 255",0,65535,"A","Auto","","",1
"TEST: P00b","P00b","0x0100","INT(B)& 255",0,65535,"B","Auto","","",1
"TEST: P00c","P00c","0x0100","INT(C)& 255",0,65535,"Z","Auto","","",1
"TEST: P00d","P00d","0x0100","INT(D)& 255",0,65535,"D","Auto","","",1
NOTE: If you use C or F in the Units Column, Torque automatically changes the Variable to Temperature, That is why I used "Z" in place of "C".
NOTE: the .csv file MUST have the ".csv" in lower case for import. I just use lowercase for all characters in the filename. And I used Wifi File Explorer
to move my files to my Android Phone. That makes it easy using my WLAN to IMPORT or EXPORT the files from my computers Browser (Firefox).
Code:
BLOCK
00
   A = 152 = 0x98  1001 1000
   B =  57 = 0x39  0011 1001
   C = 128 = 0x80  1000 0000
   D =  19 = 0x13  0001 0011
                    1  1111 1111  1111 1112
1234 5678  9ABC DEF0  1234 5678  9ABC DEF0  SAE J1979 Layout
     A          B          C          D      PID Variables - SAE J1979 Layout
1001 1000, 0011 1001, 1000 0000, 0001 0011  Received Data for Block 0x00
A7654 3210 B7654 3210 C7654 3210 D7654 3210  Torque Order of Bits for {A..D}
The PID's for Block 0x00 are 0x01,0x04,0x05,0x0B,0x0C,0x0D,0x10,0x11,0x1C,0x1F,0x20 PLUS Offset 0x00
BLOCK
20
   A = 160 = 0xA0  1010 0000
   B =   1 = 0x01  0000 0001
   C = 176 = 0xB0  1011 0000
   D =  17 = 0x11  0001 0001
1010 0000, 0000 0001, 1011 0000, 0001 0001  Received Data for Block 0x20
The PID's for Block 0x20 are 0x01,0x03,,0x10,0x11,0x13,0x14,0x1C,0x20 PLUS Offset 0x20
BLOCK
40
   A = 236 = 0xEC  1110 1100
   B = 210 = 0xD2  1101 0010
   D =  25 = 0x19  0001 1001
1110 1100, 1101 0010, 1000 0000, 0001 1001  Received Data for Block 0x40
The PID's for Block 0x40 are 0x01,0x02,0x03,0x05,0x06,0x09,0x0A,0x0C,0x0F,0x11,0x1C,0x1D,0x20 PLUS 0x40 PLUS Offset 0x40
BLOCK
60
   A = 233 = 0xE9  1110 1001
   B = 239 = 0xEF  1110 1111
   C = 171 = 0xAB  1010 1011
   D =  81 = 0x51  0101 0001
1110 1001, 1110 1111, 1010 1011, 0101 0001  Received Data for Block 0x60
The PID's for Block 0x60 are 0x01,0x02,0x03,0x05,0x08,0x09,0x0A,0x0B,0x0D,0x0E,0x0F,0x10,0x11,0x13,0x15,0x17,0x18,0x1A,0x1C,0x20 PLUS Offset 0x60
BLOCK
80
   B = 182 = 0xB6  1011 0110
   C =  64 = 0x40  0100 0000
   D =  45 = 0x2D  0010 1101
1110 1001, 1011 0110, 0100 0000, 0010 1101  Received Data for Block 0x80
The PID's for Block 0x80 are 0x01,0x02,0x03,0x05,0x08,0x09,0x0B,0x0C,0x0E,0x0F,0x12,0x1B,0x1D,0x1E,0x20 PLUS Offset 0x80
BLOCK
A0
   A = 204  = 0xCC  1100 1100
   B =   0  = 0x00  0000 0000
   C =   0  = 0x00  0000 0000
   D =   0  = 0x00  0000 0000
1100 1100, 0000 0000, 0000 0000, 0000 0000  Received Data for Block 0xA0
The PID's for Block 0xA0 are 0x01,0x02,0x05,0x06 PLUS Offset 0xA0
BLOCK
C0
   A =  N   = 0x
   B =  O   = 0x
   C =  N   = 0x
   D =  E   = 0x
The PID's for Block 0xC0 are NONE.
BLOCK
E0
   A =  N   = 0x
   B =  O   = 0x
   C =  N   = 0x
   D =  E   = 0x
The PID's for Block 0xE0 are NONE.
My 2020 RAM 1500 Eco-Diesel supports the following PID numbers:
0x21,0x23,0x30,0x31,0x33,0x34,0x3C,0x40
0x41,0x42,0x43,0x45,0x46,0x49,0x4A,0x4C,0x4F,0x51,0x5C,0x5D,0x60
0x61,0x62,0x63,0x65,0x68,0x69,0x6A,0x6B,0x6D,0x6E,0x6F,0x70,0x71,0x73,0x75,0x77,0x78,0x7A,0x7C,0x80
0x81,0x82,0x83,0x85,0x88,0x89,0x8B,0x8C,0x8E,0x8F,0x92,0x9B,0x9D,0x9E,0xA0
0xA1,0xA2,0xA5,0xA6
The PID list I am using Follows: Filename is ram1500.csv (Can't be *.CSV)
Note: You can grab these and copy them to your Andriod with Wifi File Explorer, and then Import then into your RAM 1500 Vehicle setup.
Code:
"Avg regen dist","AVG D","0x018B","((F*256)+G)*0.621371",0,65535,"Miles","","","",1
"Avg regen time","AVG T","0x018B","(D*256)+E",0,65535,"Min","","","",1
"Boost Altitude Comp","Boost","0x0170","((B*256)+C)*0.03125-[33]",0,25,"kPa","","","",1
"DEF Consumption","Def Rate","0x0185","(B*256+C)*.005",0,328,"L/H","Auto","","",1
"DEF Level","DEF Level","0x0185","(F*100)/255",0,100,"%","Auto","","",1
"DPF Capacity","DPF %","0x018B","(C*100)/255",0,100,"%","","","",1
"DPF Regen Mode","DPF Mode","0x018B","({B:0}<1)+{B:1}",0,3,"mode","","","",1
"DPF: Pressure Gradient","DPF Drop","0x017A","((B*256+C)/100)*0.145038",0,25,"PSI","Auto","","",1
"EGR %","EGR","0x0169","(C*100)/255",0,100,"%","","","",1
"EGT: Cat Outlet","EGT Cat Out","0x0178","((((F*256+G)*0.1)-40)*1.8)+32",0,1200,"°F","Auto","","",1
"EGT: DPF Inlet","EGT DPF In","0x0178","((((B*256+C)*0.1)-40)*1.8)+32",0,1200,"°F","Auto","","",1
"EGT: DPF Outlet","EGT DPF Out","0x0178","((((D*256+E)*0.1)-40)*1.8)+32",0,1200,"°F","Auto","","",1
"Engine: Run Time","Run Tm","0x011F","((A*256)+B)/60",0,65535,"Mins","Auto","","",1
"Exhaust Press EcoD","Exh P","0x0173","((B*256)+C)/100-[33]",0,25,"kPa","","","",1
"Fuel pressure EcoD","Fuel P","0x016D","((D*256)+E)*10",0,30000,"kPa","","","",1
"Fuel Rail Temp","FRT","0x016D","(F-40)*1.8+32",-40,215,"°F","Auto","","",1
"NOX Sensor 1: Pre-CAT","NOX Sen 1","0x0183","(B*256+C)",0,600,"ppm","Auto","","",1
"NOX Sensor 2: Post-CAT","NOX Sen 2","0x0183","(D*256+E)",0,600,"ppm","Auto","","",1
"Odometer","ODO","0x01A6","(A*(256^3)+B*(256^2)+C*256+D)*0.0621371",0,65535,,"Miles","Auto","","",1
"Run Time w NOX Warn","RTwNW","0x0185","(G*(256^3)+H*(256^2)+I*256+J)/60",0,500,"Min","Auto","","",1
"Turbo: Compressor Inlet Temp","Turbo CIT","0x0175","(B-40)*1.8+32",0,220,"°F","Auto","","",1
"Turbo: VGT Position","VGT Pos","0x0171","(B*100)/255",0,100,"%","Auto","","",1
"Vehicle Speed Sensor","VSS","0x010D","A * 0.621371",0,140,"MPH","Auto","","",1
Here is VSS setup for different Tire Size's.
[OFFICIAL] Torque Pro App thread
Code:
Torque OBDFusion tire size correction PID
PID:010D
Long Name: Calculated MPH
Short Name: MPH
Min Value: 0
Max Value: 255
Scale Factor: 1x
Unit Type: KPH
Equation: (A/1.60934)*1.0xx
(A/1.60943) converts KPH to MPH
Replace xx with tire size difference percentage.
To find size difference percentage go to www.tacomaworld.com/tirecalc?
I'm creating a document that contains this detailed information.
I've got the following working along with a few more on the second page.
Thanks.
Larry
2016 RAM ED 1500 Laramie CC 4x4
Need help. I posted this same message on another thread but realized it hadn't been active since 2018. I have a 2016 3.0ED that has 2 recalls. The Diesel EGR Cooler and to have that done the dealer has to perform the EPA/CARB Emissions Mod that I've been avoiding do to all the issues with power loss and reduced MPG. I have Torque Pro and the Bafx ODB2 scanner but would like advice as to what gauges to monitor/record 30 days BEFORE I have these recalls performed and then another 30 days AFTER so I have some sort of record if there is any loss of power or mpg or any other loss performance. Any help would be appreciated.
I'm afraid I don't know enough about my Eco-Diesel 2020 with 2500 Miles to even guess what you need. I do have several Parameter ID's
PID's for the Eco-Diesel that I've gleaned from this Forum and the Jeep Forum. But, I've not experienced the gyration you have been through.
All I can offer is the method I've conjured up to query the ECU for Blocks 0x00, 0x20, 0x40, 0x60, 0x80, 0xA0, 0xC0, and 0xE0 for what
PID's are available for accessing. There is a Bit set for each PID in each Block of 32 (4 - 8 Bit Bytes) for 256 PiD's.
I'm right in the middle of creating a Document that explains in detail how to decode the bits. But, I haven't been able to find the 2019 Document
that is supposed to be the latest. That is one reason I've posted the previous posting hoping someone has access to the PDF information.
Larry
Larry
Thanks Larry. Appreciate any help you can toss my way.
Good morning everyone,
Is there any where that there is a list of PID's to use with gauges. There are a few posts here and there with a few PID's. I have several and some work and some don't. But a list of them would be real helpful to have. Some place that we could add more to as we get them and use. I have read through every thing I can find and would like some thing easier to find.
Thanks is advance
Don
welcome to the site Don ,
in post # 466 , i listed the posts in this here thread where the Pids are described , you'll have to go back pages ,
but , all in the same thread , maybe copy info that interest you in a word pad and load the Pids you want in your Torque monitor.
some even posted links to the packages they use , just one load and you would have same set-up they have .
Kaz Thank you. I will go back and do that. I guess by the time I got that far my eyes had glazed over
2015 CC Laramie (3.92), DEF Delete, EGR Stage 2 Delete, Tuned, Timbren bump stops, Straight Piped, B
Does GPS/Location actually need to be on? Kills the battery leaving it on all the time.
