thanks for setting this up. WIll save us all time and frustration.We know you have posted your results elsewhere in the Forum. Now there is one place to look for oil analysis and related commentary. Encourage you repost results if you want, all new test results here please. Thanks.![]()
IS this the factory fill and your first oil change?
Yes.IS this the factory fill and your first oil change?
Hershey,It would be great to get unused samples of each of those oils tested. I not doubting you Howie12. Did you change your own oil both times or did the dealer?If you didn't do the oil yourself, did the dealer put the wrong oil in previously? There is a trend of uninformed dealers/lube techs...just saying.
Third time's a charm blue!
This is disturbing - what oil are they putting in these engines if it's NOT Pennzoil Ultra Euro L 5W-30? There was but one or two oils in the U.S. That were approved when the 2014 engines were installed in our trucks! Does the dealer add oil once the receive the vehicle from the factory?I just got off the phone with Alex at Blackstone labs. His opinion on the two samples that I've sent in was that the factory fill was not the same oil as the second sample that I KNOW was Pennzoil Ultra Euro L 5W-30. They do have a VOA of Pennzoil Ultra Euro L 5W-30 for reference.
