1 - 20 of 22 Posts
I just did my oil and filter change on my truck and need to reset the oil life, I scrolled through the steering wheel controls but did not see anything on it. Does anyone know how to do this?
It's in the manual...
Oil Life Reset
Your vehicle is equipped with an engine oil change
indicator system. The “Oil Change Required” message
will flash in the EVIC display for approximately 10
seconds after a single chime has sounded, to indicate the
next scheduled oil change interval. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate, dependent
upon your personal driving style.
UNDERSTANDING YOUR INSTRUMENT PANEL 43
NOTE: Use the steering wheel EVIC controls for the
following procedure(s)
Vehicles Equipped With Passive Entry
1. Without pressing the brake pedal, press the ENGINE
START/STOP button and cycle the ignition to the
ON/RUN position (do not start the engine.)
2. Press and release the DOWN arrow button to scroll
downward through the main menu to “Vehicle Info”.
3. Press and release the RIGHT arrow button to access
the ”Oil Life” screen.
4. Press and release the DOWN arrow button to select
“Reset”, then press and release the Right arrow button
to select reset of the Oil Life to 100%.
5. Press and release the Up arrow button to exit the EVIC
screen.
Vehicles Not Equipped With Passive Entry
screen.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
Reactions: RudolfDiesel
I had my first oil change today, actually it is the first time back to the dealer since we picked it up 6 months ago. Dropped it off at 9490 miles. On the way home we received the message that it was time for the oil change (when it rolled over 9500 miles). Called the dealer to walk me through it, and they couldn't do it. They kept saying that it was in the message center. From the instructions above, it's in the "Vehicle Info" section. First mistake.
When we bought the truck we also purchased a detail service every 6 months. When we got home, I looked at the truck in the direct sun and found places where they left polish on the truck, Second Mistake.
After finding places where they left the polish, I checked around the truck and also found that they didn't do the same treatment on the roof. When I asked if the roof was included (trying really hard to restrain my sarcasm), they said yes. Third Mistake.
Windows were not cleaned completely. They are not round, you could tell where they cleaned and where they didn't. They also forgot the sunroof and the front windshield. Fourth Mistake.
Individually each item is not a big deal, but when you have to add it all together, it's a big deal to me. I paid for a $60k+ truck and I want it to look like it for as long possible.
I go back to the dealer tomorrow. I guess I need to make sure that they have the correct oil and know how much to put in.
Is it so hard to change the oil and detail a vehicle? They had all day to get it done, no rush.
Sorry for the rant.
That's a lot of reading and fiddling. I just go to the oil life window and press reset. Works riding down the road as my dealer has forgotten to reset it both times they did an oil change.
this does not work on a Laramie Ecodiesel
Oil Life Reset
START/STOP button and cycle the ignition to the - this does not work on an Ecodiesl, the t
ON/RUN position (do not start the engine.) ransmission is locked in Park when the engine isn't running
so the rest is irrelevent
screen.
OP use arrows up and down to get to the truck icon ,
then arrow left and right to get oil life ,
by howie who wrote that last week :::: : Oil life is now reset.
I did not interpret the reset instructions correctly.
First you push and hold > to reset. Then the confirm screen comes up.
DO NOT GO DIRECT TO PUSH > TO CONFIRM> YOU MUST FIRST SCROLL THE SCREEN
UP OR DOWN TO GET THE OK IN THE CENTER WINDOW THEN PUSH > TO CONFIRM
Here’s the missing step! When you get to Oil Life and press and hold right arrow as directed for ‘Hold > to Reset’ then a Confirm screen comes up that says Cancel between up and down arrows. You need to press up or down arrows to choose between Cancel and Ok. Chose ‘Ok’ then press right arrow to conform the reset and it will change oil life to 100%.
for my Laramie Ecodiesel this is the drill:
push start button without your foot on the brake
I scroll down to see the oil life gauge
press the right arrow and the start button simultaneously
pump the gas pedal three times
press the right arrow to get the reset option. it comes up cancel, push the down arrow to get confirm
press the right arrow again to confirm
it then reset
'18 Laramie CC 4x4, '03 Ram 3500 Laramie Sport QC 4x4 Cummins Smarty, built 47 series trans
I realize this is an older thread hopefully somebody can help me. I did reset oil life reminder at my oil change, confirmed it and reminder went away. I just had the reminder come up just 3K miles later with 5% oil life. I've tried the gas pedal thing several times, unable to access the menu on the dash to reset it. Any ideas what to do?
I did mostly heavy city driving, stop & go over a couple days. Also some idling with AC running to keep kids cool over the same days. Burned maybe 1/4 tank of fuel over those days, so really wasn't that many miles of city driving. When I start the truck I get the warning oil change due on the dash , tried scrolling menu and the option for resetting it is not there. I find it hard to believe the oil is that used up in 3K and only way for the warning to go away is fresh oil.
After my last oil change, the change light came back on around 3000 miles too. Must be a hiccup in the system.
Thinking of disconnecting battery, tired of hearing the chime
The instructions in the manual (2015 ED with key not Start/Stop button) are not entirely intuitive, and Kazimodo’s post #11 does an excellent job of explaining the anomaly.
1 - 20 of 22 Posts
