NoLovely
When the timing cover is leaking, can this cause coolant loss and oil/coolant contamination as well?
There's not enough difference in those photos to be worried. It's normal for the coolant level to fluctuate in the degass bottle. If the fluid drops below the seam, then you need to start inspecting for coolant leaks.The top pic was today, the bottom one was taken on 11/30, or about 3,300 miles ago. There may have been minor temp differences on the two photos.
Any ideas?
I would be surprised if Blackstone finds any coolant contamination. That being said, an EGR delete is not a bad idea, unless you were still under warrantee.I have not checked the diffuser tube since I last cleaned it, the PO must have never cleaned that or the MAP at the time of tuning either. I will pull the tube tomorrow and take a look.
Sent off my last 2 oil samples to Blackstone today. Half tempted to park it until those come back.
If you missed it, there's another thread about timing cover leaks.Lovely
Mine had a coolant leak when i bought it found red on my driveway. come to find out there was a line that cracked that connected to the turbo as its water cooled dealer fixed but it was $$$$ i saw the quote. The oil leak my 2015 is doing the exact same thing. Took back to dealer( im not visibly loosing oil when i check it, levels relatively the same.) they said it was a front cover leak but its more of a seep not enough like yours to drip. They said at this time i can get it fixed but its not bad enough to justify fixing it in my mind yet.Been smelling oil off and on over the past few months of ownership. Truck is a 2015 with about 109k.
Noticed this tonight, appears to be oil. Have not seen any visual drips on the ground as of yet.
Any guesses on where it's coming from? View attachment 93560
Thanks, I've read about that coolant line breaking. I brake cleaned the front of the motor the other week and so far I haven't noticed any more seepage.Mine had a coolant leak when i bought it found red on my driveway. come to find out there was a line that cracked that connected to the turbo as its water cooled dealer fixed but it was $$$$ i saw the quote. The oil leak my 2015 is doing the exact same thing. Took back to dealer( im not visibly loosing oil when i check it, levels relatively the same.) they said it was a front cover leak but its more of a seep not enough like yours to drip. They said at this time i can get it fixed but its not bad enough to justify fixing it in my mind yet.
when i first saw it. it was the day after my oil change from the dealer i had a puddle under my truck on my drive way ( I FREAKED OUT lol)took it right back to them after checking my oil level. they told me it was from the cover BULLSHIT. they had spilled oil while filling my truck back up and i think filled a valley up and the spot where the cap is because they checked and i hadn't lost any oil. so i dont know if its from them spilling oil or not. but it hasnt got wetter or worse since then that was last oil change and im 4000 in to my new one. so grain of salt lol.Thanks, I've read about that coolant line breaking. I brake cleaned the front of the motor the other week and so far I haven't noticed any more seepage.
Thinking back on it the residue really didn't have much of a smell to it, so I wonder if it was old.
Magnesium was flagged because it appears to be satanic. Afterall, 666 can't be good.Any idea on what might cause the magnesium high?
Typically, there are two signs when the turbo coolant hose has sprung a leak.This is the pulley right between the valley. Correct me if I'm wrong but that looks like it is reddish coolant on the housing? Is there a housing that can fail or is my best bet replacing the failure prone coolant hose going to the turbo?
Whereabouts is that crossover tube located?Typically, there are two signs when the turbo coolant hose has sprung a leak.
1. A lot of people say they can smell coolant.
2. If they identify a leak, it is most often coming down the back of the block and sometimes seen around the transmission bellhousing.
I'm not sure what you're seeing at the front of the engine. I'm not saying it can't be coming from the turbo coolant hose, but it seems that most coolant leaks at the front of the engine are coming from the water pump or the crossover tube.
