Service bulletin on oil selection for Cummins engines. The last part is of importance to both earlier ( pre-'19) and newer (post '18) engines.
Not sure where the 0W-40 reference is coming from but the new 6.7 uses either 10W-30 or 5W-40. One big difference is the new 6.7 has hydraulic lifters which needs the oil to keep them pumped up correctly. Cummins has approved 5W-40 for years and lots of oems are going to 10W-30 now for fuel economy.It is hard for me to comprehend the concept of 0w40 being OK all year around for both engines if you live in cold country but if not you must use 10w30 for the 2019 and newer engines coupled with the fact that this oil must meet a Cummins spec and API CK-4 and the 0W40 can be CJ-4 and doesn't have to meet the CUMMINS spec.
I don't have a Cummins so won't take the time to go to BITOG but lots of experts there and perhaps they have an explanation. If anyone does either have one or find one please post it up here. I'd be interested in reading it to see what I can learn.
btw, Cap you might want to reread your note and correct it.
All the best,
"Service bulletin on oil selection for Cummins engines. The last part is of importance to both earlier ( pre-'19) and newer (post '18) engines."btw, Cap you might want to reread your note and correct it.
All the best,
yes, that was my error. I should have typed 5w40 but the point I was trying to make is the same. My apologies. I have quoted the relevant portions from the TSB belowNot sure where the 0W-40 reference is coming from but the new 6.7 uses either 10W-30 or 5W-40. One big difference is the new 6.7 has hydraulic lifters which needs the oil to keep them pumped up correctly. Cummins has approved 5W-40 for years and lots of oems are going to 10W-30 now for fuel economy.
You are absolutely correct Cap. I am not sure what was wrong with my brain that night. Perhaps it was the cold weather, the long snowmobile ride prior to looking at the forum and the third brandy. Shame on me. Jeez I hate when I do this!"Service bulletin on oil selection for Cummins engines. The last part is of importance to both earlier ( pre-'19) and newer (post '18) engines."
What should I correct? The pre-'19 engines are from 2018 and earlier. They can use the 15-40...according to the bulletin. The post '18's are from 2019 - 2021. They are NOT to use that 15-40W oil, according to the bulletin.
Thought I read the bulletin correctly. Beats me. Just trying to add information on the issue to this forum. It sure is "dead" on the HD topic section, partly because there is really not much to talk about as the trucks just seem to soldier on with few major issues. If it were not for the CP4 discussions there would be little to have any forum contribution topics other than transmission, tires, add-ons, tuning, DEF etc. Seems the Cummins owners have no serious motivation to post trouble as there is little trouble to talk about.
Now maybe we could talk about the 800 miles or so per gallon of DEF consumption? Some of the HD Cummins with the new hydraulic valve engine have now gone over 100K miles with few to no issues. Just the way it is.
The older, solid lifter, Cummins was a classic motor with a long reputation for reliability. It is a bit loud in operation and does need some periodic valve adjustments. Kind of "old school" in design with block and other components. That just may be a good thing.To be honest nothing was wrong with the older 2018 cummins 6.7s. The older 6.7s still had alot of potential for more hp/torque. Don't know why cummins has tried opening a new can of worms.
NO.Too much power.... say it aint so capt!
