That only applies to the ecm tuning.I have been told that the original GDE tune will allow the cruise control to be set at 15mph. This is how owners know the tune is still there and working.
Canyon
OP asked how to determine if a GDE trans tune is still in place.I have been told that the original GDE tune will allow the cruise control to be set at 15mph. This is how owners know the tune is still there and working.
Canyon
Should also be able to tell if the GDE trans tune is there by the behavior of the gear controls on the steering wheel. If you can select a gear with the buttons and then manually move up or down - or move the trans back to full auto mode by holding down either the + or - buttons - then the GDE trans tune is still there. If the buttons don't behave that way then unfortunately it's gone.
Bob
I forgot about that. I will check it out.Should also be able to tell if the GDE trans tune is there by the behavior of the gear controls on the steering wheel. If you can select a gear with the buttons and then manually move up or down - or move the trans back to full auto mode by holding down either the + or - buttons - then the GDE trans tune is still there. If the buttons don't behave that way then unfortunately it's gone.
Bob
