1 - 5 of 5 Posts
Just put on my Weather tech mudflaps. All went well. Helpful hint: the front and back are different and not labeled from Weathertech. My problem is that the lowest trim screw on the right front spins. I can't get it out or tighten it. Dealer looked at it on a short visit and could do nothing with it. Any help would be appreciated
I had the same thing. I just had to play with it until it grabbed. Think it has something to do with the wheel liner (and or something behind the liner) and getting it to line up properly. I just had to try try try try try try again, before it finally threaded back in.
The alignment of the plastic liners on mine were off by half an inch. I had to pull part of the liner out and re-align the metal sheet nuts that attach to the liner. I even noticed that my fender flares are off just as much! Turns out that whole wheel well plastic and flare was installed half an inch off.
1 - 5 of 5 Posts
