1 - 2 of 2 Posts
What is the difference in the race tune, looked on site but could not find an explanation. Thanks
All Jeep Grand Cherokee
1.*** Engine and transmission warmed up (engine > 80°C, trans > 60°C)
2.*** Vehicle at stand-still, steering wheel straight
3.*** Engage SPORT mode (2014-2015 pull back on shifter once when in "D", 2016 press button on dash)
4.*** Press brake pedal as hard as possible
5.*** Accelerate engine to more than 1700rpm
6.*** Release brake pedal and apply accelerator to WOT as fast as possible
At the conclusion of step 6, RACE mode is engaged and so shifts are with faster times than normal and *no torque management*.
RACE mode will exit when any of the below are fulfilled:
1.*** Accelerator is released less than 92%, OR
2.*** Current engaged gear reaches 6th or higher, OR
3.*** A drive mode change occurs (i.e. exit manual shift mode, turn on tow/haul), OR
4.*** Steering wheel is turned
After a successful RACE mode engagement, the function is blocked for 45 seconds. This allows all the shift elements to cool down from the prior use.
1 - 2 of 2 Posts
