1 - 6 of 6 Posts
Does anyone know if the hitch is a class IV hitch and what the tongue rating is with the weight distribution hitch attached?
Seems like a big difference between the 2 axle ratios! A hemi with 3.21s can only tow a few hundred pounds more than an ED with 3.55s!
I didn't realize how much different the ratings were ! I guess with the 3.92s u will probably sacrifice a few mpgs wether it's a hemi or an ED.
Correct me if I'm wrong !
For sure you will be spinning more rpm's as you drive down the road...
Unless you're towing 8000lbs over mountains the diff's not going to matter. The transmission is fully capable of setting engine rpm.
1 - 6 of 6 Posts
