Last Tuesday my oil pressure warning light came on and the gauge would dip at the same time when I was at idle. The engine would labor a bit when this happened. This would pulse between bad and normal several times. I had my truck towed to the dealer and found out yesterday that they found metal shavings in the oil filter and the pan and are going to replace the engine.
Has this happened to anyone else? Any insights or advice?
The dealer thought this could take between 10 days and 3 weeks depending on parts availability. They put me in a rental, at least.
I'm really bummed because I won't be able to take extended trips with the same level of confidence.
