1 - 5 of 5 Posts
I assume this is not good. The rear diff is slinging fluid on the fuel tank and it sings like a canary.
Pinion bearing? Rebuild?
that would be a pinion seal leak, although if the rear differential is making noise you probably need to take it to a shop to have it looked at. Rebuild a rear end is most of the time better left to the professionals.
yeesh. not a good. are you sure you didn't just get residual oil on there? i see no oil leaking on the backside of the yoke where it meets the diff.
1 - 5 of 5 Posts
