1 - 4 of 4 Posts
2017 Ram 1500 Laramie Ecodiesel 4WD,PPE tranny pan;AFE oil pan,diff cover, intake & exhaust; GDE.
I am upgrading the limited slip rear differential in my 2017 4WD Laramie ED to an Eaton Detroit TrueTrac. In researching Master Install kits I found serious quality complaints with all of them. There aren't any discussions yet addressing these issues. I would appreciate some advice and guidance, both positive and negative, to help me make a wise choice.
I went thru issues with the master kits for a DANA 60-2 from NAPA, the bearings were all SKF IIRC, but the side bearings wer Chinese & would start spalling out in less than 10,000 miles, I started getting my kits from TIMKIN & problem solved. I've also found that some reviews on things are written by morons, sometimes you just have to think about comments, I would think that bearing & seal quality would be the main issue. If you're just replacing the carrier you shouldn't need to mess with pinion depth, so that leaves preload & gear clearance, not a lot of need for a master kit IMO, axle seals & side bearings unless you have a tone of miles on it , then do pinion bearings & seal, the pinion shims should remain the same.
Thank you for replying. This is my first post. The previous owner of my vehicle was obviously an idiot as he ignored the EGR cooler recall. I bought it in February and have been doing a progressive build. Some of the things I am doing are precautionary becaused I don't know what other things have not been maintained or kept up to date. Some of the reviews on Timken bearings from China have been a bit alarming.
I wasn't aware of Timkin's being made in China, I had hell with the side bearings on Dana 60's they were SKF IIRC, pinion bearings were fine, parts selection has gon to the dogs, I worked for NAPA on 2 occasions in the 70's and 80's and their parts were top notch. I imagine if enough complaints came in then these crappy parts would dissappear.
1 - 4 of 4 Posts
