81 - 98 of 98 Posts
Yes absolutely shit design and part, this is the case with most euro engines,
So the question is...
Do you wait for this shit sensor to go bad on you in middle of nowhere... Or you just change this sensor as a preventive maintenance??
Add me to the list... 2015 JGC, stock with ~98k miles.
Like others have said. It would be nice if someone could come up with an aftermarket part designed to eliminate it from becoming a "maintenance" item. Problem I see is the ED is currently such a small market that it prob doesn't make good business sense... yet.
You should still be covered by the powertrain warranty, no?
Sent from my SM-G960U using Tapatalk
Yes, we have max care and it was not used.
What part of the country are you in where they covered the reluctor wheel replacement?
I'm "working" with my dealer in Northern Michigan. Service manager's District Manager is fighting me on getting this covered, saying it was the cause of the service not the crankshaft sensor. Both were replaced during my vehicle repair at a cost to me of $1,250.00
I hope to get the cost of the sensor and labor refunded, but right now they want to claim that all of the labor is associated with the reluctor wheel (which they say is not covered).
Maybe your precedent will help my case.
Thanks,
The extended warranty on the engine that we all got to 120k will cover you. I was in el Paso at the Dick Poe Dodge Ram. Service guy said he sees it a lot and knew exactly what to fix and said I was covered.
There's no extended warranty on the engine. The Engine Crankshaft Position Sensor is covered, but not the reluctor wheel from what I can see.
Yep, you're right, looks like you just need to find a dealer that'll play nice like mine did. If they're nice, they can attribute the labor costs to the position sensor and absorb it that way.
Just a thought, if they won't play nice, you could tell them to prove beyond a shadow of a doubt that the sensor itself didn't hiccup momentarily, causing the reluctor wheel to fail. It's a Longshot, but worth the effort to save 1-2k.
Add my truck to the list of reluctor wheel failures. 2014 Ram 1500 Big Horn ED with 100,170 miles. FYI this was not covered under the ED Settlement Extended Warranty. Just under $1900 with tax in PA.
Lemon Ecodiesel , read the PDF file in post #86 or #87 , the sensor is covered , it is the bigger price of the 2 parts ( $565 US ),
the reluctor wheel was $75 US a few months ago , print the text and bring it to the dealer , ifyou had the AEM done you are being robbed by the dealer .
this is the first time I read of any tech changing only the wheel ,
they ALWAYS push to change the sensor at the same time , while the transmission is away from the engine
that is a first for me .
Sensors are backordered until late June at least. The wheels are backordered as well but my dealer found one from an Ohio dealer.
I wanted to get it fixed. Looking to get rid of this truck soon.
Mine went out a few months ago at close to 80,000 miles on my 2015.
My max care covered it.
The dealership had the truck done the same day as it happened.
Lost it about 7AM waited an hour for a tow, then an hour wait for diagnostics,then home.
The dealer called about 4 PM that it was ready to pickup.
No drama when it went out had pulled off a side road to the main road going through the gears normally til about 5th and just like turning the key off,
just quit running.
Discussion Starter #94
just quit running.
They must have had 10 techs on your truck working like cocaine crazed apes to get done that fast.
No, as they put it wasn't too bad they just unbolted and slid the tranny and t case back a few inches and went in and pulled the flywheel.
They actually had trouble getting the sensor out and had to retap the mounting for it, it wasn't the first one they had done.
I had mine go at 98.2k miles. It's in the shop now waiting for the part to arrive. I was told MaxCare covers it. I'll see it that's true when the truck is ready.
81 - 98 of 98 Posts
