1 - 2 of 2 Posts
" 5 x 550 bolt patern rims, was on a tundra comes with pro comp all terrain tire size 275/60R20. "
Will the rims fit my ram with no flares and how are the tires in the winter?
Sent from my SGH-I317M using Tapatalk
Gleb, I just posted my own reply to a question I asked the group about offset….(in this section on Wheels/Tires) I've been on a steep learning curve with wheels and tires the last two weeks. Here's what I think you'll need to find out:
1. The Offset of the wheels coming off the Tundra (as per my post..look for something on the inside of the rims or measure it…
2. The outside diameter of the tire you listed above (I'm guessing that it's fine, because it looks like the same size that came on my Laramie
3. The Rim width….
You need to know the offset to know whether the rim/tire combination will clear suspension components inside the wheel, or whether the tires will ride too far outside the body without the flares, and kick up stuff onto your paint/body work….
Since my stock wheels are 20x9 with 19mm offset, if your Tundra wheels are close to that you should be fine….
dpiotrowski
1 - 2 of 2 Posts
