Hello ,
I have a 2014 1500 ecodiesel in my shop , it had the problem with the SCR cat , and it was beginning to count down from 200 miles to 0 that it would't start anymore .
Fitted it with a new SCR cat , and got the code P2BA9 along with de p20EE just as described in the service bulletin . so far so good .
updated Pcm with latest calibration ,
erased all codes
checked def injector quantity (30 ml)
Did the tank level reset it was 50%
filled a gallon of add blue
and went for a n hour highway drive , after that the message was still there saying car wont start anymore
put it out and indeed it wont start ,
did the hole Scr healing procedure again , after i reset the pcm so it would drive 60 mile again , same result , but after i tunr of the car it wont restart , and i couldnt program it again to do the 60 mile drive .
Tried everything but it just wont work with a hard DTC P241D (forced engine shutdown) but this is the only DTC i get , not anyother DTC has set since then .
After i reflashd the PCM again , i can get the DTC reset and i can get it to drive for another 60 mile , but that message wont clear , did 4 SCR healing trips of well over an hour with constant speed of 60 mph .
i dont get any codes , but the message just wont clear .
I hope someone has a good idea
Thanks
Frank
erased all codes
Thanks
Frank
