1 - 15 of 15 Posts
Okay I need some help I’m new to the ecodiesel I got my 2016 with 107000 on November 2 on the 12th engine light came on said service electronic throttle control and it would not go over 2 thousand rpms I was just down the street from the dealer so I took it to them they just called about an hour ago and said we got you ready they had sent it to the dodge dealer to be fixed I was told it was the egr valve then the cooler. So I called dodge to ask them what they done all they said they done was changed the air filter that it was extremely dirty and restricted the air flow and that fixed it does this sound right to anyone?
Not sure yet they called and told me its ready but we are about to close so I won’t have it until Friday but according to a friend of mine at the dodge dealer it’s running fine and they drove it around with no issues
Hi: Tapkbp1313... Along with a new air filter they may have found your truck just needed a refill of "Blinker fluid"!!!
I just recently had the same issue. When I got my truck back the cab was filling up with exhaust fumes. The fuel line was backed up.
I’ll have to look my paperwork to see what all they did the first time when I took it in for the Service electronic throttle
Same thing happened on my truck after adding the GDE tune. The error code would clear under the factory tune but return shortly after flashing back to the GDE. GDE tried to help by rewriting the tune a few times but the issue returned. I took my truck to the dealer with the GDE on it and they were able to determine it was a failure in the turbo. The truck has been great since the turbo was replaced. Funny that the "issue" seemed to be "solved" by the factory tune.
2016 CC Laramie Longhorn
This code has been my number one nemesis since buying my 2016 back in 2019. I just checked my post a created the last time I got the code. It didnt create much traffic as far as responses. I believe the last time the code may have been cause by a loose connection under the truck on the driver side. I have also read on here someone there is another connector driver side under the dash that could be causing it. The one under the truck some forum members have tried to remedy by zip tying the connectors from possibly backing out or water intrusion. Ill try and find the post with images that I found on here when researching and post a link.
2017 Ram 1500 Tradesman commercial duty, CC, ED, 6'4"
Generic default alarm/action for a bunch of different issues. That computer will put in that mode with most engine sensors seeing a bad condition. Had mechanic explain to me when mine triggered (was faulty oil signal from Turbo).
Time to get familiar with 5 things:
BDE tune $1500 best money ever spent; shuts off EGR and stops the waste gases from pluggin your intake and fouling the MAP but for now you can just:
The EGR diffuser tube, two 10 mm on one side two 8mm on other; throw away $27 rubber band gasket and replace with $1.25 high heat o Ring from auto store
soak in gasoline and ream with a bittle brush untill clean, reinstall
The MAP Sensor carefully disconnect the pigtail and torx 40 bolt, clean with MAP or safe O2 sensor cleaner spray; it will be completely sooted over and clogged; spray the tip but do not touch; spray clean
Put back clean
OBD2 scanner This you will need to clear the Turbo boost pressure error codes that leaves you with no power and top speed of 45-65 mph stuck in obummer mode
The start button this is the most important thing.. you have to fast press the start button in order to get the truck into "ON" mode without it actually running. its the equivalent of the key have turned past ACC.
These trucks wont allow OBD2 to clear codes unless you are in "ON" with no motor running. Right there I saved you some stealership time and cash installing injectors, turbos, filters and the like.
if you dont clean these the problem WILL return.
Also if you arent going to tune out the EGR then you can look forward to this filthy process every 15k possibly.
Make sure you check MAP frequently like every oil change. if it plugs up AND the EGR tube plugs the higher pressure in tube heats it WAY too hot then it melts the foam thing under the engine case cover and it may even catch fire. This WILL warp your intake valves and smoke your motor.
All in all its not a bad truck if you tune it. Most say after BDE there maps are forever more clean.
1 - 15 of 15 Posts
