How about a load of Walnut rough cut lumber at 7000 lbs? Hauled from up state NY, to South Carolina in one day.
nice! gonna get the surface planer warmed up?How about a load of Walnut rough cut lumber at 7000 lbs? Hauled from up state NY, to South Carolina in one day.
I actually did stop and adjust it on the way home.You might have got a little less sway by adjusting the WDH to shift more weight off the rear axle to the front. Does your truck have the Integrated Brake Controller?
Yea fully understood.Wow that’s an overload.17,850 CVW is 1900 over max for 4th gen platform. 8,550 GVW is 700 over combined max axle, 4800 is 900 over max axle, 1400 is 250 over max receiver with WDH. Hope the TBC was set on 10 because she would need all the help she could get on a panic stop. Hard right hard left steer if someone pulled out in front of you with that weight and distribution would have been a roll over recepie. And a hard pothole at speed could break the non full floater axle.
I’m not chastising you as you said you know you were over and won’t rent one again that heavy. I’m sure you took it slow & careful. TH and 6th was the best way to tow that weight TT. Glad all turned out well and hope the fam had a great trip. That is some beautiful country up there. I have been Eugene to Florence and Florence to Coos bay. And yes it is a testament to what our lil 3 liter diesel 8 speed can do.
