Hey guys!
Sorry for the long post, but I've searched everywhere and found a few with similar issues, but no resolution... and I miss driving my truck! Forgive me if this has been covered/resolved and buried in the forum somewhere.
I bought my 14' ED a few years ago with 50k miles it and put on another 50k miles thanks to a long work commute and a few road trips over the years. The truck as been awesome for the most part, I change the oil and filter every 10k miles, and fuel filter every 20k using Mopar filters and now updated oil. last year the truck shut off on me while idling in traffic with CEL code P0087 (Fuel Rail Press. Too Low), started back up with no issue and I was able to get home. Since the oil/filter and fuel filter change were due, I changed both, primed the fuel pump (key on, let pump run/ key off, repeat x6) as usual and the truck was fine. No issues at all through 2 oil changes and 1 fuel filter change. Changed the oil and fuel filter about 4k miles ago and last week it shut off at idle again with CEL/code P016F. Thinking it was a faulty filter somehow (Mopar), changed it again, primed, and was good to go... until a week later, the truck shut off again while idling with CEL on and P016F code. So I tried something- I started it in my driveway, let it idle for a few minutes and it shut off with the same code. I primed the fuel pump 6 times, started it again, and let it idle for about 15 mins with no issue. Started to drive it to work the next day, and shut off again as I was idling down my driveway. Parked it and have been driving my car since. I hate dealers and mechanics- been lied to too many times so I'm hoping to either fix this myself (prior aircraft mechanic/ now drive-way mechanic), or at least learn as much as I can about it if I have to take it somewhere. (not all chicks are clueless when it comes to car/truck maintenance!)
In short:
- Truck: 14' ED with ~104k miles currently (all highway) w/ GDE Hot Tune since 50k mi
- Problem: Shuts off at idle but runs fine at 1000+RPM (first code- P0087, then code P016F, but not both at same time)
- Tried: Changed fuel filter multiple times (w/ Mopar)
- Fuel level rarely low enough for low fuel light / only fuel up at 2 local locations. Filled tank up to full, still shut-off at idle with P016F code.
- Thoughts: After a ton a research, I'm thinking it may be the HPFP failing, but would that only be an issue at idle? If I stop and keep it revved to 1000 RPM, its fine...let it idle normal (850-ish?), it shuts down with code...
Any info or suggestions appreciated!!!
In short:
