I looked under the front of my new Laramie and I'm concerned about what I believe should be tighter tolerances in building the truck at the factory. The front of the lower suspension arms are mounted to the crossmember with adjustable cam bolts. The cam bolt on one side of the truck is at the bottom of the adjustment range, the cam bolt on the other side of the truck is at the top. Seems to me this would make future alignments of the truck difficult. The suspension arm visibly sits higher in the crossmember on one side of the truck.
I can post a pic if I'm not explaining this correctly.
Also not happy with the weld splatter on the front crossmember, but that's another issue.
