1 - 15 of 15 Posts
Had anyone done this? My problem is at bank 1, sensor 1; so I'm assuming it's on the exhaust manifold somewhere....???
Any tips? I need to get this done soon because my inspection is due this month.
Thanks!
Flipside.... A code is needed in regards to folks with opinions and personal experiences and possible fixes , Without a code, No one can even attempt to help you out...
The code is P0030.
Can you assist?
The code is P0030.
Can you assist?
that sensor is pre turbine inlet. check the internet for parts schematics and you should be able to locate it. it is quite possible you will have to get at it from the underside of the truck or through a wheel well since the turbo is located in the back of the V.
Having been there done that, hunt up a tool looking like this, well, take a look at the sensor first, there's also a spanner sensor tool, for tight spaces.
Thanks guys! I think I can see it from the underside of the truck (passenger side). It's there only 2 O2 sensors in our trucks? I see one toward the back as well.
I didn't think diesels have O2 sensors. You should double check that.
be careful. you may not be looking at O2 sensors. this truck has a number of EGT sensors. pre turbine, pre doc, pre dpf, post dpf.
i know there are also a couple of NOx sensors as well as manifold presshre and pre dpf pressure.
i dont know if this truck actually has O2 sensors.
From my bluedriver scan data base, see attached on sensor/location: I have never pulled that type of sensor, last 1 I did was a knock sensor on a Lumina, so U would have to get with the guru's on here. Definitely get a 2nd opinion before you do ne thing from what I post as I am not a mechanic,., just have played when necessary, lol....
T-bird :cool:
I believe there are two O2 sensors on the EcoDiesel. I base this off of moparpartsonline which shows upper and a lower 02 sensor for the 3.0 liter eco diesel. Does anyone know how to use torque app or something similar to test them to make sure they are performing up to spec? Does anyone know what the normal parameters of the two 02 sensors should be?
1 - 15 of 15 Posts
