Very true. I sure wish we had all the information regarding what HPFPs are being used on what years/generations/models of trucks and, why isn't the Powerstroke and Duramax engines dealing with the same. I know they did years ago.Remember that the 2500/3500 are being moved back to the CP3.x pump. Not sure that same solution works with the 1500.
I've heard that Ford and/or GM were covered by recommending a fuel additive in the owner's manual whereas Ram didn't. The lack of guidance leaves Ram more liable. Who knows how true that is, but that's what @OhioTech seems to believe.Very true. I sure wish we had all the information regarding what HPFPs are being used on what years/generations/models of trucks and, why isn't the Powerstroke and Duramax engines dealing with the same. I know they did years ago.
I think I'm having the opposite feelings. I'm sorta' sad about bringing home the '22 and selling the '19! I hope it's a fleeting sensation.My Dad always said about boats that the two happiest days of your life are the day you bring it home and the day you sell it.
I put the EcoDiesel in that same category.
On the Cummins, they are going back to the previously used CP3, which was never installed on EDs.That doesn't add up since the recall on the Gen 3 EDs for the HPFP is based on dates (May 29th, 2019 to January 21st, 2022) and the recall states that "some" (some being 31,794 RAMs) may be affected. My 2022 ED isn't part of the recall and I was built on the 13th of January. Since they are replacing the HPFP on the 2019 and 2020 Cummins and 2021 and on production are not of interest it would seem they have a replacement pump albeit in limited supply for retrofitting.
I agree, I run Hot Shots EDT at every fill up and try to only gas up at QT which has 5% Biodiesel. I’ll do the recall at some point, but am not losing any sleep over it in the meantime.It’s a lack of lubricity in the American fuel…
Use an additive, worry less!
That's what I plan on doingI got my recall letter the other day, plus an email notice from Carfax about it for some reason.
I'm having a hard time wrapping my head around the pre-notice heads up that there's a recall coming when the problem child component isn't available yet. IMO all this does is erode confidence in the reliability of the engine in my truck. It sure makes me think twice about heading out on a road trip in the middle of winter with a truck that may or may not get you where you're going.
It also makes me glad that I didn't jump on a GDE tune yet due to the needed software upgrade with the recall. I know you can do the additional spare ECU with the GDE tune and this confirms why it would be a good decision to go that route. I'm also wondering if you'll need to have the ECU with the GDE tune upgraded by them after the new pump is changed out?
I'm thinking I'll probably leave my truck stock, get the recall done and then sometime in the future look at what truck I want next a couple of years from now.
Without any real knowledge of the tune, I agree that the dealer will have to reflash to make the new pump work and that would probably make the current GDE tune inoperable. The recall will then require a new/updated GDE flash.I got my recall letter the other day, plus an email notice from Carfax about it for some reason.
Buy from a reputable fuel source, use a fuel additive, and you'll be fine.I've got a trip planned for Alaska towing same trailer for next year. Truck has worked well, really well, but I'm not very happy with Ram/Stellantis right now, given the lack a fix. I'd be really P/O'd if it died half way up the Alaskan Highway.
