1 - 7 of 7 Posts
Showed up at the dealer for an appointment made to find a rattle. Found and stopped it last night, too late to cancel. Went anyhow to get parts for a permanent fix. No parts to fix screws holding an inner fender well. I chose to pass on ordering the parts and will fix it permanently with my own bolt/nut design. They still took the truck to check on and do any recalls. There were three they did.
First is a P 15 where they flashed RFH. That has something to do with a radio frequency. It did NOT affect any of my 3 key fobs.
Second is a flashed DDM. That's something to do with a door module.
Third is the RRT 14-037, which is a flash of the PCM. . Powertrain Control Module flash.
Done and gone. I noticed nothing different in the way the truck operates.
At the dealer right now for that vibration issue, here there is only one recall for that fob... no pcm...
My dealer checked and said mine only had one recall for radio frequency something said it only affected the radio. I told them I wasn't worried about it currently.
Reactions: chris12559
Discussion Starter · #4 ·
They ran the vin number to check. My take is recalls are vehicle specific.
Makes sense that way...
Mine had two that Captainmal had, the radio frequency one and the PCM flash. I asked at the dealer if the PCM flash was the one that raises the horsepower and fuel mileage by 20%. No such luck.
I took mine for the P15 RFH and was treated to the RRT 14-037 Rapid Response Transmittal. That is all they did.
1 - 7 of 7 Posts
