1 - 11 of 11 Posts
I've had a 14 Ecodiesel longhorn for about 3 years. It's always had P275/55R20 tires on it. Now its time to buy new tires and I noticed the correct tire listed for the truck is P275/60R20. I'm getting 28-30 mpg on what I have now and am used to the speedometer being off a little. I don't do any towing and drive 75-80% highway. Wanting to keep my mpg up, any ideas on which size to go with and any recommendations?
Remember, the stock tires are low friction for mileage. Many here don't like the SRAs for various reasons, but mostly quality. They worked for me and I never had any problems. But since I do go off road, I went with Goodyear kevlars on my second set. I can't see any difference in mileage and if there is, it's small. The truck seems to handle a bit better and and I see no difference in the ride. They may be a bit louder. Since I put them on, I have done dome off road over very rough rocky terrain without incident.
You realize that your mpg readings are inaccurate with smaller tires as the truck doesn't travel as far as it thinks it does?
Mine has 285/60R20 tires so it shows a little worse than it actually is. But they're an LT tire that's made for the weight
I can't comment on MPG effect, but I've been running Toyo Open Country AT IIs in 275/65/20 for many years now, they are superb tires. Little bit of road noise, and the LT makes for a slightly rougher ride...but they really work well. I got 50K+ miles out of my last set and if it weren't for the snow driving going completely to hell, I could have got at least another 10K from them (Wet was ok and dry was perfectly fine, even at that mileage).
I popped a new set on my ED just a few months ago...
Welcome to the forum - first post.
Went through two sets of P (passenger) rated tires on my '14 Ecodiesel and then wised up. Put a set of "E" rated Cooper Multi-Mile tires on and they lasted forever and looked brand new when I traded that truck. Never took a hit on fuel mileage, keeping things in the 26-29 mpg range normally. Did run 60 psi in them with what I thought was a good ride.
FWIW. I'm pretty sure any LT or AT tire will cause a loss in mpg. I went with Falken Wildpeak AT3 275/60R20, because I liked the look and blew out one of my SRAs', but had about a 3mpg loss.
I run the same as Tarheel above, at first I really liked the tire, but after putting approx 8k miles on them it seems the road noise has gotten worse at highway speeds and I’ve noticed a drop in mpg also.
I can vouch for Captainmal, I have the same E load Cooper Hwy tires. I run mine at 65 psi in summer, 60 for winter. The ride is fine too.
While towing I saw no mileage hit. Empty load maybe 1-2 mpg loss, but I can still get over 31 mpg though.
P rated tires are not the best for towing in my mind.
Buy at least a D rated tire. You won’t be sorry.
I put a set of BFG KO2 on and very pleased with the performance
If mileage is your main concern, watch the tire weight and try to keep it close to the 41 lbs of the oem tire.
1 - 11 of 11 Posts
