192k miles and no tone wheel failure.
Do you have the ECM update done?192k miles and no tone wheel failure.
I don't think so.Do you have the ECM update done?
As we know, it doesn't do much other than instead of the truck possibly causing an accident on the highway it will allow the engine to continue to run until you can safely get off to the shoulder of the road.I don't think so.
I'm not worried.As we know, it doesn't do much other than instead of the truck possibly causing an accident on the highway it will allow the engine to continue to run until you can safely get off to the shoulder of the road.
Yes only certain Vin# . I know the early ones were not involved. Maybe they changed suppliers or materials after that and caused the problemsWhat's the consensus on this issue, were only certain batches problematic?
I have a 2016 EcoD and when I first learned about the problem I hadn't received any recalls and when I asked my dealer about it, they said nothing comes up with my VIN#????
Only issue I'm currently having recall-wise is the HPFP that they still haven't designed apparently.....
Mind sharing the out-of-pocket cost? Also did they replace the rear main seal like many are mentioning?The failure is due to a defect, so in theory the replacement should last longer. Mine failed at ~106K - missed the extended warranty expiration by a little less than 6 months so had to pay out of pocket. The failure happened on May 1, the part didn't come in until May 16th, and they didn't finish the replacement until May 23rd. A failure on a vacation trip would have killed the trip.
Keep in mind any Transmission shop can do this for probably a Lot less. Easy Peasy....Mind sharing the out-of-pocket cost? And did the replace the rear main seal like many are mentioning?
