1 - 2 of 2 Posts
Vendor
The changes in the tire size and a tread pattern instantly get a reflection in the way your truck handles and performs. If you mostly use concrete roads and not looking for advanced off-road capability, all-weather truck tires will be your best bet.
They will provide optimal performance in all weather conditions and ensure good fuel efficiency on the pavement. Unlike the off-road tires with aggressive tread design, they provide a quiet and comfortable driving experience.
If you are looking for reliable and fuel-efficient tires for a daily commute check out the list of the tire options provided below.
#1 Dunlop Grandtrek AT20
Features:
  • VersaLoad Technology ensures consistent handling, ride comfort, and tread wear in a wide range of load conditions
  • Aggressive tread design enables excellent grip and control from season to season
  • Circumferential tread grooves help pump water away from the footprint for excellent wet traction
  • Multi-Pitch Tread Design Technology reduces noise for a quiet ride and comfortable driving experience
#2 Firestone Transforce HT
Features:
  • Circumferential grooves ensure extra traction in wet conditions
  • Computer-designed shape and body contributes to ride comfort
  • 5° Noise Reduction Technology minimizes noise generation
  • Advanced high modulus tread compound helps to prevent damage
#3 Cooper Discoverer SRX
Features:
  • Strategically placed bumpers keep the grooves between the tread open to stabilize the tread elements
  • Indicators change as your tires wear, making it easy to determine the tread life remaining
  • Computer-designed sidewalls come with an extended bead filler and performance compounding
  • Compounds are formulated with the highest content of chemically-coupled silica for maximum wet traction
#4 General Grabber HTS
Features:
  • Duragen ultra high-strength technology for improved treadwear and better mileage
  • Response grooves and stabilink bars for long-lasting all-weather performance
  • Comfort balance tread cushioning system
  • Fuel efficient tire compound for improve mileage
1 - 2 of 2 Posts
