1 - 9 of 9 Posts
Hey guys,
I wanted to get your help with this trailer I am about to bite the bullet on! I cannot wait. It is 3,003 pounds dry. The rest of the specs are in this link if you wouldn't mind checking it out. I have a longhorn ecodiesel that can pull 7,000 pounds. I don't think I'd have any issues pulling this thing with passengers and gear!
Cruise Lite Travel Trailer by Forest River
Have a great week,
Mo
2014 Lonestar EcoDiesel 4X4
I don't think you'll have any problems towing this small trailer. The specs don't list the trailer GVWR, but is shows a NCC of 881lbs, so lets say GVWR of 3,885lbs. Well below the capabilities of this truck. The Longhorns do not have a huge payload, however. As long as you don't load the truck with five adults and fill the bed with a generator, extra water and other camping gear, you'll be OK.
Awesome, thanks a lot! I will ask for those number this evening and get back to you.
Also, I don't plan on hauling that much extra gear so I should be good!!
I pull my TT 28 ft 7300+lbs. It pulls great. I only get 12.8 mpg but I drive 70mph. Great truck. RAM ED cc 6.4 bed 3.92 gears. air system.
Thanks, Dave. I have the 5.7 bed with 3.55 gears. I have the air suspension as well. Will keep you posted!
That trailer would be NO PROBLEM for the ED, That is almost half the weight it is able to haul .
I have been thinking about a TT what kind of price range is that bunk house ?
Thank's
mike
Yeah, not going to be a problem. You can save some weight by making sure the water tanks are drained before hitting the road. They total 78 gallons at 8.33 lbs a gallon that adds up quick.
Discussion Starter · #8 ·
Thanks for the info guys. I really appreciate and like what I am hearing. Mike, this is a pretty unique model from what I have been looking at. These are going anywhere from 9-15k depending on the seller. The one I am looking at is closer to the 9k end of the spectrum!
Your truck will have no problem pulling that lite travel trailer. The only problem you may have is remembering that it is behind you. I tow a 7,000, 28 foot travel trailer (my 3D has 3:92 gears) and the only problem I had towing was a blown tire. The truck pulls so well that I couldn't feel a difference in towing from 4 tires to 3 tires. If it hadn't been for someone who pull along side of me on the freeway I would have never known there was a problem until it was to late. My trailer has wide spacing between the wheels (supposedly for better trailing) the problem with wide track spacing is that when you have a flat the other tire can't keep the flat tire's rim off the road. With standard tire spacing this was never a problem as with my old 1992 trailer, where only the tire became damage.
I will be adding tire pressure senors to the trailer's tires before I take it out again.
1 - 9 of 9 Posts
