1 - 13 of 13 Posts
Has anyone noticed their truck (with air suspension) leaning to one side? I noticed mine the other day seemed to be leaning towards the driver's side. When I measured from the ground to the fender I found a 1" difference side to side (both front and rear). I tried running the suspension through all of the settings and they work fine but there is still the 1" difference.
Sorry mine is the same both sides.
I've noticed the same thing. I measure each day for a few days in a row. It was always off by different heights each time. I haven't noticed lately though.
Yes, by design. But, there are position sensors for each corner. I suspect the problem has to do with one or more of these sensors and/or controller.
Measured mine today after sitting overnight in the entry/exit mode. Right side, both front and rear was about 1/2" higher than the left side. I wonder if that is by design to compensate for the camber of the road? Anyhow, will check periodically and report if I get different results.
Reviving an ancient thread because hey, I used the search function. My '16 Laramie with air suspension is also uneven side to side, the driver's side is 1/2" lower than the passenger side in the rear. Anyone else have this issue and get it resolved?
Dealer says they can't find a spec on height variation and some variation is within spec. Yet they don't know what the spec is.
It seems like a lot of trucks ,regardless of manufacturer have a slight lean and usually to the left , some folks speculate because of weight of fuel tank , my Toyota Tundra had about 1-1/14 inch lean to left , on the Tundra site they use to call it the GangSta lean . :cool:
Mine was about 1/2" off as well. I used adjustable links to level the truck. While I was raising those, I also compensated the left side to increase it a little more. I'm within 1/4" all around now.
Do you recall how much you changed the link length to compensate side-to-side?
Did you make adjustable links or are they available somewhere?
Hi guys I fixed my 2016 Rebel air suspension by reprogramming the ride height with the AlfaOBD app it was pretty easy. I made a video of how to do it:
1 - 13 of 13 Posts
