Hello everyone!
Just wanted to reminder everyone of a recall for certain 2014-2018 Ram 1500 diesels under campaign number W68/NHTSA 20V-475. This is for the crankshaft position sensor.
The magnetic material attached to the tone wheel on your vehicle provides a signal to the crankshaft position sensor. If this signal material is lost, the engine loses its ability to synchronize injector pulses and cam timing. This loss of crankshaft position can result in an engine stall, as well as loss of the ability to restart the engine.
To close recall W68, the dealer will replace the tone wheel.
To see if you are affected by this, you can visit recalls.mopar.com or send RamCares a private message with your VIN. We are happy to help you set up an appointment as well!
Thank you!
Thank you!
