1 - 20 of 25 Posts
I have been listening to the four by four guys telling me that 17" rims are the way to go when using your vehicle for off roading...Why is this? and what are the pro's and con's?
Maybe more tire sidewall?? U would rather scrape tires than rims on rocks. Also you can prolly air down a taller sidewall vs shorter sidewall more.
cent frum my fone so don't cumplane about spelling or grammer
Yes - more tire sidewall. This allows you to air down, increasing traction, while maintaining some ground clearance.
More "offroad" tires are available in smaller diameters than in larger ones, which means you'll get better performance and less chance of getting a flat offroad.
Picking a sidewall is common, but tougher offroad tires can absorb this.
More sidewall on the tire. That way when you "air down" (drop your tire pressure down to 5psi-15psi depending on your wheel & tire combo) the side wall will flex and contouring to the terrain as you drive over it, giving you more grip. Also less chance of damaging your rims with more sidewall.
Also, I think someone mentioned that the 17" tires are LT vs. P for the 20's.
I run 17" for a few reasons. the rims on the 20" are out almost as far as the tire, meaning they are more likely to hit rocks. if you hit a rock under your tire the bigger side wall tire has more give to adhere to and around the rock making for a smoother ride. and the big kicker is, you can get both 17" and 20" in an LT rated tire but you are going to shell out almost $100 more per tire for the 20"
It sure was good and correct.
Those 20" wheels and tiny tires are for city profiling. Always use spinner hubs with reversing or stationary centers. Tint illegally dark also so you can't be identified.
The 20's are on Tire Rack for around $120 ea. That's much cheaper than I thought they would be.
not to mention, even under everyday driving. The 17's will ride better. for the same reason they do everything else better. More sidewall. the only time this would really be untrue is on road type racing, where generally the less side wall the better to a degree.
FP3 figured it out.
the only time this would be untrue is on road type racing, where generally the less side wall the better to a degree.
That's why all the drug dealers, inner-city cowboys etc. have small sidewall tires. They need the extra speed to run from the cops.
When I read something from anyone who has it figured out, I have a cold one in their honor. C U L.
My buddies wife works radio dispatch for the Ontario Provincial Police. She says "you can out run a cruiser, but ya can't outrun Motorola". I always liked that one.
The mpg would depend on the outer diameter and rolling resistance, no idea what the two compounds are like or the actual width differences. If they are the same final diameter, close to the same heat rating and contact patch they will be pretty close in mpgs, or at least within the error of any of the inputs in the calculations.
There are LT tires for 20" wheels although sparse.
rolling resistance more or less will depend on the tire more so than the rim. diameter, width and weight all play into that one.
1 - 20 of 25 Posts
