1 - 10 of 10 Posts
Hi, have a 2015 Ecodiesel Limited with about 40k miles. A couple times while on highway with cruise activated it was if the brakes were applied briefly (but pretty hard) and the cruise disabled. Really bizarre and disquieting while otherwise enjoying a nice drive.
Anyone else have any experience with this sort of thing?
Welcome to the forum.
Haven't heard that one yet. Are you saying that the brakes are actually being applied without touching them? I don't believe that these trucks have automatic forward braking sensors. :confused:
Being a Limited, does it have adaptive cruise control? Maybe it is sensing something in front of you and slowing you down? Not sure how that works, never had it on anything.
These trucks dont have adaptive cruise control but the traction control and stability control are still active when using cruise control. If you hit a puddle of water or took a corner to fast that could cause it.
Welcome - First post.
As you read above, you may have a unique situation. Never had an issue with mine but I rarely use cruise control. I'm a bit leery of these computer control features. You figure something out, report back.
I have had this happen multiple times while on the freeway. Most of them at the almost exact same location on the way into the office. By time I look at the screen, I will catch a glimpse of the cruise control deactivated message.
The first time it happened I panicked and stopped at the dealer, which I drive past on the way into the office everyday. They ran a diagnostic but did not find any codes. I was at maybe 10,000 miles at the time.
It was the third time it happened that it dawned on me that it's happening in the same spot where there is a dip in the freeway causing some float coming out of it and a slight right curve.
It has happened a couple other times, other than that spot, with similar conditions. An overpass on the freeway with a hard dip/bump causing float coming out of, or into, it with the cruise set at 72-74mph.
Doesn't happen often, but when it does, it always throws a jolt in me that something just went really wrong. Especially how hard it shuts it down. Yes, almost like the brakes were slammed on for a second.
Have not had this happen in my Ram, but my Tahoe would do it like @hawgwildinLB mentioned every time I went thru a particular dip on the highway at 80. If I was in left lane nothing, in right lane cruise would turn off. Decel was rather abrupt, I imagine it would be worse in an EcoD
Oh my. Daughter just bought a new Tahoe this past week. Will ask if she has a similar experience. Never heard of anything like that on any vehicle.
I have the same truck with similar mileage.
Never experienced this and I use cruise always.
Must have been a fluke. The truck does not know how to stop on its own.
It is possible that a scenario similar to what @hawgwildinLB described where the vehicle stability control causes the cruise to disengage/brakes applied. If the vehicle has had any front end work or feels like it pulls/handles funny there could be an issue with the steering angle sensor. The steering sensor works in conjunction with vehicle speed and accelerometers to determine corrective action by the VSC.
@IHAWK see if you can pick up a pattern or location that it happens, might give the dealer an idea where to look.
1 - 10 of 10 Posts
