Looking at General Grabber HTS60 or Cooper Discoverer HT-plus for replacing my current set. I tow my TT about 2,500 miles a year. Just looking for a good set of XL tires. Any thoughts?
Appreciate the advice. I’m still on the original Goodyear sr-a tires and they wore terrible with all towing I’ve done over the 3 years I’ve had the TT. I tow a micolite trailer that has a tounge weight loaded at bout 750-800lbs. Good WD hitch with it too. Just seems the OEM tires are too soft. Are there better LT tires?I'll be the voice of dissent here ... only just for the heck of it .... because I have had XL and LT tires on trucks before .... you'll do what you want anyway
With a tongue weight less than 1000lbs, and an annual trailer use of 2500 miles .... if you compare what you are getting in XL's and what your regular usage tires will carry (provided that you're not being stupid when you load the truck), all you'll really gain is a rougher ride the rest of the year and no real safety gain, assuming that you are towing withing legal weights for the truck and you're using a WD hitch ....
That said .... XL's aren't as bad as LT's, but they're still rougher and noisier than what comes on the trucks.
I am sorry but I don't really have any advice on what tire to buy. I just wanted to be the voice in your ear that said "hey think a bit first about what sort of ride you want to have during the 75% of the time that you aren't towing".... it seems that you have thought about itAppreciate the advice. I’m still on the original Goodyear sr-a tires and they wore terrible with all towing I’ve done over the 3 years I’ve had the TT. I tow a micolite trailer that has a tounge weight loaded at bout 750-800lbs. Good WD hitch with it too. Just seems the OEM tires are too soft. Are there better LT tires?
I just put on the Cooper discoverer 20" HT, 2000miles. I really likke them but I lost about 3 miles per gallonLooking at General Grabber HTS60 or Cooper Discoverer HT-plus for replacing my current set. I tow my TT about 2,500 miles a year. Just looking for a good set of XL tires. Any thoughts?
I would HIGHLY recommend the Michelin Defender LTX M/S! They weigh about the same as the stock tires. They are excellent for towing, plus you'll maintain your fuel economy. The Max Load rating is 2,679 lbs per tire, which is more than you need.Looking at General Grabber HTS60 or Cooper Discoverer HT-plus for replacing my current set. I tow my TT about 2,500 miles a year. Just looking for a good set of XL tires. Any thoughts?
Better to be safe than sorryJust my two bits... I tow a lot. Either my 8k tt or my boat. My'17 eco has 70k miles on it and 40k of it is towing. My OEM SR A's only lasted 30,000 and that was rotating every 5K. I put Load Range E Hankook AT 2's on because I get a much warmer and fuzzier feeling with a heavier duty tire while towing. I rotated the tires yesterday and there is easily 60% tread left. The ride is a bit stiffer and mileage takes a bit of a hit but was a good tradeoff imo.
Sent from my SM-A505U using Tapatalk
Perspective ::Just my two bits... I tow a lot. ...................The ride is a bit stiffer and mileage takes a bit of a hit but was a good tradeoff imo.
Most OE tires (including the OE Goodyear SRA) are not high quality tires.Just my two bits... I tow a lot. Either my 8k tt or my boat. My'17 eco has 70k miles on it and 40k of it is towing. My OEM SR A's only lasted 30,000 and that was rotating every 5K. I put Load Range E Hankook AT 2's on because I get a much warmer and fuzzier feeling with a heavier duty tire while towing. I rotated the tires yesterday and there is easily 60% tread left. The ride is a bit stiffer and mileage takes a bit of a hit but was a good tradeoff imo.
Perspective:Perspective ::
The O.P. tows very little. He'll be trading a nice ride 90% of the time for a rough ride all the time to tow 10% of the time.
I can't best 11mpg.And, towing my 8k tt with my GDE tuned truck tends to average closer to 15 than 12. To each their own. I'll keep putting load range E tires on until i wear her out. And I'll suffer my +/- 1mpg loss in mileage gladly.
