Gear ratios tire size and MPG. Loooing to buy
22K views 22 replies 12 participants last post by  Nemesis
#1 ·
Ok guys I have been anxiously awaiting the light duty truck diesel for quite some time. For years I had dreamed of a cummins 4BT set up roght in a half ton rig could really pull in some mileage
Now we have the Eco Diesel. It seems to be living up to the hype and I am intrigued.
If and when I order one of these guys I will be getting a crew cab 4x4. SO being said I want it to look like a 4x4. No not a crazy lift but just some 285/60/17s probably on the stock rims as I don't like the deep looking stick way out there wheels.
Now by going to an over size tire what concerns me is the small displacement of the engine and how much it could affect its performance and in turn mpg. I am thinking that the 3.92 gear ratio would be in order here to make up the difference in tire height.
Am I going to lose 30-40% of my mileage due to the taller tire?
I am not going to lift it so yes my aerodynamics will be slightly affected but not over the top.
What do you guys think that are running them? I mean if its going to drop me down into the teens then I might as well get a 2500 for about the same money where there is power to spare and a jump in tire size will not affect things .
#2 ·
Search around some of the older threads, many of the early buyers have changed tires and/or lifted their trucks. There is a really good thread breaking down tires sizes. Going to a slightly larger tire has not hurt these trucks too much - most are loosing about 1-2mpg with larger tires.
That being said, most owners are still pulling down 25+mpg and better on the highway - with 3.92 gears and slightly taller (non-stock) size tires. Some guys with mild lifts are getting that kind of mileage too. One of the members has 35's and is still getting 24+mpg.
#3 ·
I have 34.1" tires that are 10 ply with 3.92 gears. Most of my early mileage was towing getting 17 mpg. Not towing I avg 21 mpg with 21.6 being my best so far.
I think it is the best of both worlds having a truck with real tires, not the cheesy passenger tires the truck came with and I still get better mileage than my 2013 hemi did with passenger tires.
#4 ·
I went with 285 70R 17, getting 25 MPG when commuting through the Finger Lakes hill country for a 2 hr round trip. 23.5 religiously on my regular 1/2 hour commutes. Still holding off on the 2" leveling kit, maybe next month...
#5 ·
I searched tire rack and could not find 285-60-17 tires but did find 285-65-17 tires which should be a bit taller. They have an overall diameter of 31.6". The stock 17" tires, P265x70x17, are 30.7" overall diameter. The stock 20 tires have an overall diameter of 33" So with something like you are contemplating you will still be lower geared overall than the trucks with the 20" wheels. Ram offers both rearend ratios with both wheel sizes so given the the different tire diameters you can get 4 effective overall ratios. You have no need to go to the 3.92 due to the tire change you are proposing since it is still lower geared than the 3.55 with the 20" wheels and tires. I am very happy with the overall gear ratio of my truck with the 20" wheels and tires and the 3.55.
#7 ·
Good question... I would have thought the same. Here's what I found. That would explain why one reviewer mentioned tire rub at full wheel turn.
#10 ·
Therefore... ratio = (3.55 X 33/31.6) = 3.7:1 Pretty close to half way, Howie.
#12 ·
Well Howie, you are 3 hours ahead of us, so I haven't had my Margarita for the evening yet... Cheers!
#14 ·
Thanks for the clarifications....I assume each different truck with different rear ends and different tire sizes are calibrated for accuracy on the speedometer? And if i were to switch between 17s with winter studded tires, and 20s with summer ones, i would in effect be throwing my MPH off as well as increasing my fuel mileage a tiny bit, all other things remaining equal?
#15 ·
yes the odometers and speedometers are calibrated as supplied by the factory. Since they are electronic they can be easily recalibrated by the dealer and maybe some other clever people. If you do not recalibrate them you will induce an error in the speedometer and the odometer based upon the change in tire circumference from original. It will indicate a change in mpg but most of that change will not be real since you will either be covering less or more miles per indicated mile. There may be a very small actual change due to overall ratio change but I believe most will not be a real change only an indicated change.
#16 ·
Well perhaps. But the dealer has some factory hard wired limitations. They can change to meet the following tires and wheel sizes only:
235/80/17
245/70/17
265/70/17
265/70/17
275/60/20
285/45/22
These sizes are off the factory software version as of 5/24/14. Perhaps a newer or a forthcoming version will add more options for the dealer to select.
#17 ·
Ok good information here.
I am perfectly capable of calculating the difference for myself even if the computer in the truck and speedo is not correct.
However if I did get a truck I could go with the 285 70 17 and they would be close to the factory offering on the 20" rim so they could utilize that tire size when calibrating. I went through all this back when I had my 06 2500 and they used the tire size from the power wagon
My biggest concern is can I avoid a serious hit to the fuel economy and still have it look like a truck. I know its tough to have it all but we can dream right?
now I would be curious to see like trucks with same gear ratios difference in mpg between stock 17s and 20s.
Or difference in mpg between gear ratios
#18 ·
Real world numbers- 3.92 gears, 275/60/20 (stock size) Falken Rocky MTN ATS tires, no lift/no level, and I consistently get 23-24 mpg highway in my hilly area at 65-70 mph. On long trips, I have averaged over 25 mpg on some stretches while doing 75 mph.
#20 ·
Ok so heres the test question
Can you get the 20" wheel option which inherently comes with a signifigantly larger tire diameter with the 355 gear ratio in a 4x4?
And if yes there is the answer I need to my question as to if I would need the lower gears or higher gears to run the tire size I desire and maintain fuel efficiency
Ram still hasn't updated their site to allow you to build a 2015 model
