Phife9355 14 Ecodiesel Build
57K views 41 replies 26 participants last post by  Longhorn ram
#1 ·
So this is what I came from:
It was a 2011 Kia Optima SX, which had way to much stuff on it, but I wanted a change, tired of scraping the ground everywhere I went, so I returned it to stock and traded it in on a 2014 Ecodiesel. I knew I wanted my next car or truck to be diesel, since I already had a Jetta Sportwagen TDI for the wife. At first I wanted to get the new Mazda 6 Diesel, but I just couldn't wait anymore and when the Ecodiesel starting arriving at dealership I had to try one out. After the test drive I was hooked. I just happen to get the only one at the time that was located in the Jacksonville area. The guy who sold it to me didn't even know that they had a 1500 diesel! Here it is the when I got it home:
Nothing special but what I wanted, 2014 Ecodiesel Bighorn SLT
First mods done:
Gator SR2 tonneau cover and changed out the stock 4" exhaust tips for Mufflex 5" tips and added a Blue Spark tuner from RollinSmokeDiesel!
Picture of 4" vs 5" tip
5"tips
Next Mod, change out stock antenna with a short 4" antenna, hated the look of the stock antenna.
Changed the stock Quad headlight to Black housing clear side, with H13 LED headlights. These things are bright, better than any HID kit I have used before.
Next mods to come, Set of 20x12 Wheels with 305/50s with a 2/4 drop, and more motor mods.
#3 ·
I got them off of ebay, easy just do a search for 14 ram headlights and they will pop up. The paint on the inside is a black matte finish. Lights are close to stock, the plastic on the back feels thinner than stock by tapping on it, but over all close to factory. I did have to send one set back due to one of the lens looked like someone used windex on it and left it to dry. Could only see it when the lights were on, but it was replaced fast.
#4 ·
Small update, Painted the front bumper matte black, it blends in great with the rest of the truck now.
#7 ·
Question on the Mufflex stuff. I just checked their website, does anyone know if the muffler delete that they offer for the hemi will work for the ED? The muffler on our trucks looks similar to the hemi one. Also, do the tips mount the same way as the stock ones, the bigger tips look real good.
#8 ·
Added a set of Motometal wheel 20x12 with 305 50 20 Nitto 420s. Love this set up on the truck.
#9 ·
Very nice truck! Now paint the grill black or replace with a black grill and remove "RAM 1500" badges.
#11 ·
Can't find those headlamps anywhere... Do you remember or can you provide seller?
Also what did you do for fog lights?
Need better lighting options leave rural and the quads are blah
#13 ·
Added a set of fender flares today, kept them matte black to match the front and rear bumper.
Reactions: 14Punisher
#14 ·
Installed a set of the AFe intercooler pipes, install is pretty straight forward, other than AFe silicone couplers are hard as hell to work with, even when using a lite coat of oil on them. Getting the stock hoses off the stock intercooler is the biggest pain of the whole installed. Did have to trim the stock cover so that is would fit again, and you have to remove the foam on the driver side for the AFe pipe to fit. Spools faster since i got rid of that big u the stock hot side made to connect to the intercooler. Did find oil on both the hot and cold side stock pipes when I took them off.
#18 ·
Worth they money, yes. The low end to mid range is improved with these, but i suspect its mostly because its due to the shorter hotside pipe. Feels like the torque band happens at a lower rpm range than before. Spool time is so much quicker than before. Warn you the install is hard because of AFe silicone couplers.
Reactions: Sasquatchilly
#22 ·
dropped about 1.5-2 mpgs with the new wheels and tires.
#21 ·
Any difference with that SB air filter? Mpg drop?
#23 ·
I will know this weekend, there is a dyno day coming up that I'm going to, to see the numbers. no MPG drop with the filter that I could tell of, My MPG drop came from new wheels and tires
#24 ·
Got my new grille painted and installed it, not bad for a $105 grille off ebay.
Installed a dual Hornblasters set up on the truck, Outlaw train horn up front behind the front bumper and The Bandit horn mounted on the passenger side of the truck. Horns are operated by two different switches. Mounted the 2 gallon tank and compressor in the bed, with a secondary 2 gallon tank under the truck.
The Bandit mounted under the truck
The Outlaw mounted behind the front bumper
#26 ·
Yes they are loud, but i live in southeast georgia/northeast florida area and no one knows that their car came with turn signals.
Other note was going to dyno the truck today, but truck was too wide for the dyno.
Reactions: Eugene
#27 ·
Today drop the rear 2" to level out the truck, reverse of what most guys do on this forum, but I want a street truck not an offroader. Pretty simple install 1 hr with the right tools. More than pleased with the outcome. Ride is close to stock, one thing that I could tell is that the rear doesn't move around like it use to with the stock set up, when you get in the throttle hard.
before and after pic
#30 ·
Small mod today to the truck, added an aux airline with quick connects to the air tank for any roadside emergencies.
