Looking for thoughts on a travel trailer weight. Currently have a Jayco Jay Flight 24’ with a factory empty weight rating of 4,700 lbs. Scaled it out with all of our “stuff” loaded and a full tank of water, weight came out at 5,750 lb with bit over 600 lb of tongue weight.
Trailer I’m looking at is a Keystone Cougar Lite 28RLS with a factory weight rating of 6,150 lbs and factory listing of 760 lb tongue weight. With a straight transfer weight of the camper stuff guess it would be another 1,050 lbs heavier, or at least as a starting point for figuring loaded weight. Both have same size fresh water tank. Figure a tow weight of 7,200 lbs? My WDH is a Pro Series 49903 with 1,000 lb bars.
The question I have my 2014 is rated at 7,670(?) lb of tow weight, based on my experience, towing my current camper, I don’t see this has being a problem, isn’t the weight limit due to cooling issues with the truck\motor combination? Goes without saying I would get GDE tune with the engine braking option. Further I have the Outdoorsman grill on my truck.
So anybody else towing towards top end of this range and what have been your experiences, is this doable or should I just walk away. Not wanting to jump into the deep end without know how deep it is.(don't want to be the reason for the accident) As for my experience going on my 4th summer with this camper\truck combo, stickler for details on maintenance and keeping up with checks on both the camper and truck, tow at or bit faster than trailer tires ratings. Like I said truck doesn’t struggle to tow this trailer, hottest I have seen it get western South Dakota and it was over 100 degrees that day, oil temp hit 260 degrees pulling a couple long grades. I have not towed in the mountains can’t comment on that.
Thanks.
Thanks.
