Did this today , removed the plastic trim around the hole for the tool to lower spare ,
had to stick the strip '' under '' the plastic trim that brings juice to the electric tailgate release
and '' over '' the spare tire tool hole , no way I was going to install in a slalom patern , so
removing the lowest plastic part was best option , still have room to stick the rod in there ...
used the harness that others have suggested , made the job easy , soldering only one wire .
I modded the harness during the winter to add the reverse wire (( so there was no removing one of the tail lights
to get reverse juice as seen in many you tube videos ,
much easier do splice the harness sitting down at a table , and tape it all nice ,than messing with the truck' wires ))
''' reverse wire is the one in the center of socket '''
I used the led kit in post # 17 by pqw3413 .
and Curt harness in link here :
CURT Manufacturing 55384 Replacement Vehicle-Side Custom USCAR 4-Pin Trailer Wiring Harness, Trailer Accessories - Amazon Canada
shop for price :
pulled out trailer brake socket to clip the harness properly , easy finger removal , 2 clips to squeeze and pull out .
Rubbing Alcool to prep surface .
table with rags to receive the tailgate during work .
