121 - 140 of 144 Posts
I wouldn't spend that kind of money on what 'might' fix a very problematic system. Delete and you'll be way ahead of possible future problems.
I dont know where around here I can get a delete done.
Nobody will advertise the service, just have to find a local shop you trust. Shop familiar with diesels is even better.
Buy the tune and exhaust yourself.
Update: after about 3 months with P203E code and DEF level gauge slowly going into the red, running only 3 gallons of distilled water for the last 3 weeks in DEF tank, the gauge started working again, woo hoo!! Went to run errands today and gauge not working when left home. Made last stop, started truck and "poof" gauge is at 1/2 full.
I was getting pretty worried about getting the dreadful no start count down and a new tank would be required to resolve. I will only run highly diluted DEF from now on and hopefu;lly not have this issue again.
Just a follow up.
This started for me on 7-14-18. My DEF level sensor failed somewhere between 69,000 - 79,800 miles. The DEF level sensor is molded into the DEF tank and if it fails, you need a new DEF tank, if you are required by vehicle smog testing to keep all of the emissions in tack.
I ended up replacing the DEF Tank after trying for almost 6 weeks to get FCA to pay for based on the fact that my truck is registered and licensed in the state of Utah in a county where I need to get emissions test. Under federal emissions up until 80K miles, all components are covered if the vehicle is registered in a place where emissions test are required and you need to pass that test in order to get registration and or tabs.
I am still not through with FCA and will be talking to them again on Monday. But I got tired of there BS and having to start my truck with a wire every time I need to drive somewhere.
During the process I visited 2 different RAM dealerships and talked to them about the issues. Each time, they plugged it in and tried to reset codes. One dealership said the level sensor was possibly bad. If not that, then the PCM. They wanted to charge me $2,600.00 for the DEF tank. The other dealership told me only the DEF pump was bad and they wanted $1,500.00 for a new DEF pump.
The codes where the same for each dealer, they both had WiTech micropod II's that where linked to WiTech software.
How 2 different trained and certified techs came to 2 different conclusions while using the same tools is one of the things I am talking to FCA about. That should not happen.
What I ended up doing to troubleshoot on my own time is get a 3 day subscription to Tech Authority. This is the same resource that FCA engineers and Dealer techs have.
TechAuthority
I read up on the MIL codes and learned just how intuitive it was to follow the workflow and logic in trouble shooting a issue. It is simple. Most folks should be able to do this. Certainly, a factory trained technician. Even level 3's.
Next I purchased a copy of AppCar software and installed it on a windows 10 laptop. Within the PCM module, there is a diagnostic interface to see live data. I interfaced my LX code scanner to the OBDI II port of my truck and paired it with my software and laptop. I went into the PCM module and selected the UREA system analysis where I could see real time info on voltage, volume in mm, temperature and concentration. The only parameter I could get in real time was temp. The others where reading 0.00. Using my 3 day Tech Authority I could look at schematics and see that the temperature data is coming from a different wiring harness. So that made me suspicious of the other four wire connector which attaches to the DEF pump.
Next I looked for those part numbers on TechAuthority and found them. Next I googled the part numbers. I got multiple hits for the part numbers. The official Mopar site is the most expensive. Often 50% more in cost than the 30 or so authorized Mopar online parts shops. The same OEM parts at different price levels. Go figure!
Clicking in the return hits on google I also found new OEM parts on eBay at almost 1/10th the cost of the official Mopar site.
https://www.ebay.com/itm/DEF-Pump-E...okee-Ram-and-Promaster-14-16-NEW-OEM/253825959935?_trksid=p2485497.m4902.l9144F
Still I was feeling ripped off. I mean, this thing did not even last past 80K. How in the world did this part even make it out of review? FCA knew this part could fail at anytime? Yet, they still chose to release it and go into production with it.
Next I remembered somewhere here in another thread mention Car-Part.com--Used Auto Parts Market for used parts. I went there and entered into the search area what I was looking for. I found a DEF tank and DEF pump out of the same wrecked 2015 eco D with 26K miles about 1 hour away. I called the auto salvaged yard that had it listed and they wanted $350.00 for the DEF tank and another $300.00 for the DEF pump. I continued to look at the results from my query on car-part.com and found a 2016 eco D with 21K miles in Oklahoma. They wanted $300.00 for the DEF tank and DEF pump combined. For another $50.00 they shipped it to me UPS and I had it within 5 business days.
I just got it installed yesterday after work. It took me about a hour. The first thing I did was pull the DEF pump on my truck and put the DEF pump from the wreck on it. Using my laptop with AppCar, I went back into the PCM module and checked the UREA section to see what values I was getting. Nothing new, it was the same as my values in my DEF pump. So that told me that perhaps it was the DEF level sensor in my tank. So I put the new to me DEF tank in and the DEF pump that came with it back in. Put all the connectors back together and wrenched the tank in, put back my skip plates and cross support. Then I cleared the codes, looked at my UREA section in the AppCar software and saw a value for level in mm, urea concentration and voltage.
Man I was happy. I put the starter relay back in and started my truck with a key fob (the first time in 6 weeks) and then test drove my truck. I got about 4 miles and cel came back on with the same message, that I needed to see dealer to have my DEF system serviced. Once I got home, I reset the codes again. Turned off my truck and went inside the house for a beer. After beer, I went back out to see if it would start. It did. Great. More beer and some sleep was in order. So that is what I did. Today, I drove it about 60 miles on the interstate and all codes remained off.
Problem solved. But FCA is not off the hook. I still have a bone to pick with them.
Now, I still have my original DEF tank and DEF pump. I will keep the pump, as I might need one of those again. Perhaps. We will see. Regarding the tank, I was thinking about cutting a hole in the top and yanking out that DEF level sensor to see if I can find out who is responsible for the POS design so I know who to bitch at later. Unless someone here has a better idea, that is what I will do.
My old DEF tank with removed DEF pump.
Thanks for this great thread. Just finished reading the entire thing. I have a few questions that I didn't see addressed. My 2017 has this problem. My gauge showed zero and the light came on. I added 5 gallons of Peek brand. Light stayed on and the gauge didn't budge off zero. A while later, the "Won't start message came on". Strangely, mine was 1200 miles when I read most peoples are several hundred miles. I'm now down to 850 miles left. Drained the tank and am now taking it out per sheepdogtrail pdf. Thanks!!! I plan on trying the boiling water and slowly adding fluid after getting it back in the truck. Now some questions...
  1. My dealer say the tank is now $3600 plus labor... $4000 time I get it out the door if nothing else is wrong.
  2. Back in #46 Dr Honda says something about "Reset the ECU's DEF level"... "Tell the ECU you put in the DEF". I have a OBDLinkLX. Will I be able to do these steps with it?
  3. If I hit the "Will Not Start" I plan on using the Relay Jumping mentioned. Is jumping this passing the full starter motor current going though this jumper or is this simply a low current trigger? Point being can I run a pair of wires from it to a switch in the cab?
  4. What is the strait poop on the Delete option. I got the Street GDE Tune long time ago. Get 28mpg locally and above 30mpg on the Interstate if I keep my foot out of it. I noted that GDE went dark for a while and they're back now. I assume because of Fed backlash. I talked to them, and they said no... they can't help me. It appears they don't offer an off-road anymore. I read here in this thread that it depends on whether my state does emissions. North Carolina, so I don't think so, but isn't this a Fed thing? I note some shops around here have notices posted that NO WAY WILL THEY DO A DELETE... massive fines and such.
As I work through this cleaning, I'll probably have more. :cool:
Thanks guys!
Q 3 = low current trigger that thriggers the relay only ,
I remember reading about some member who did the wires to the inside of the cab thing until fixed .
Q4 - GDE had to make a deal with EPA to avoid $$$$$$$$$$$$$$$ fines , they
will not sell or discuss the pre-EPA tunes , can't blame them , they did what they had to
to stay in business , it appears they did not throw customers under the bus
by giving EPA all the list of owners with old tune .
you can still get full delete tunes by shopping North of the border , even GDE gave those guys
praise for the quality of their tunes : it was HD diesel supply , now they are gone , but these 3 are also good :
- Home | EOC PERFORMANCE PARTS LTD
- MrTuning : MR Tuning
$ 3600 plus Labor :oops:
there is a company in Canada that services those un-serviceable DEF tanks
2 days ago I saw the price at $400 to fix the DEF tank , today I see $ 500
I did not look toroughly at all pages of the site ...
To recap, my DEF gauge was on zero, filled with 5 gallons Peak. Gauge didn't move. Somewhat later, my "will not start in 1200 miles" came on and marched down. During that time, the gauge never moved. It is now at 800 miles left.
I removed the tank. Added near boiling water. The first two gallons had added industrial grade vinegar 45% to the mix. It would have been at about 15%. The rest filling to the brim with boiling water was just diluting it. It would be about 3% acidic (somewhat less than white food vinegar). I left this overnight. Twenty-four hours later, drained and flushed with about 5 gallons of distilled boiling water. I re-installed the tank and added only one box of Peak Platinum. Gauge and message are still there. So far, I've driven about 60 miles on this in hopes of it finally catching a clue. No luck so far.
I'm quite discouraged that I'll have to bite the bullet and get a new tank or take a chance on a refurbished or used tank. From my reading, it appears that the US Feds are really cracking down on vendors and now even going after end-users with fines and forcing to re-install DPF systems. I don't see deletes from Canada as an option.
I have a few more new questions. ;) I'd like to learn a little more about the DEF part of the system.
  1. Is the DEF injected all the time or only during Regen?
  2. If the gauge is showing zero, will the computer still trigger a Regen and try to inject the DEF that I know is in there or will it just skip the regen and continue to clog with soot?
  3. Point being... if I jury rig the starter relay to start after the "will not start" point occurs, and keep plenty of DEF fluid in the tank will I be causing in additional damage? IOW, has anyone used the relay trick long term?
Thanks.
DEF has nothing to do with regen or the dpf at all. Its just there to make the scr work and can only be used when the scr is within a certain temp window. Often it gets too hot during regen for the def to be used so it actually gets disabled during regen.
OK, so I've read some more. Is this correct?
  • The first muffler type bulge is the DPR and it catches the soot that would be called "rolling coal" on older diesels.
  • The regen burns extra fuel to raise the temperature to burn up this soot and pass it down-stream.
  • The DEF injector is down-stream of the DPR and before the second larger muffler type bulge being the catalytic converter type thing that needs the DEF fluid to work.
So my earlier questions become...
  1. Does DEF still get injected if the tank has some even if the gauge is telling the computer that there is none? IOW does the catalytic converter continues to operate correctly or is it now going to get clogged up?
  2. Would there be any other potential damage caused by starting the engine with the relay trick?
first bulge is called DPF ( diesel particule filter ) it contains 2 parts ,
first the exhaust goes thru the DOC , (converts carbon monoxide (CO) and hydrocarbons into carbon dioxide (CO2) and water. )
second part in the canister is the particule filter , ( catches soot until regens turn that soot to ash )
the canister is supposed to be able to collect ash until +/- 300,000 miles .
During a regen fuel is injected with exhaust valve open ( during exhaust cycle ) that is what raises the
temperature in the exhaust to +/- 1200 F , burning soot into ash that stays in the canister .
the next bulge is the SCR ( Selective Catalytic Reduction ) , that uses a urea-based diesel exhaust fluid (DEF)
and a catalytic converter to significantly reduce oxides of nitrogen (NOx) emissions ,
right at the entry of the SCR is where your DEF gets injected ,
your second last question cannot be answered easily , you have a 2017 , so you have a DEF quality sensor built in the DEF tank
could be a few different failures , is it the level sensor , is it the quality sensor , is it the wiring harness , is it the tube between the
DEF tank and injector ???
if it is only the fluid level sensor , there is a company in Canada that fixes the tanks , it's a fairly new thing ,
they write : "" DEF tank repair service is limited to resolving problems with
fluid level sensor in the active tank. they do not repair heating
element related issues. "" $400
the miles to no start is to force owners to get truck's emission fixed , so no hill effect reported
by using the relay jump trick until fixed , the regens will happen normally even after reaching the zero miles
to no start .
*** You might find useful info on testing your DEF system in the PDF file at bottom of post
called Recall R60 procedure .
Thank you for the very thorough response. This was very helpful.
I've been under the assumption it is my level sensor, but here are my symptoms.
  • Once the gauge first moved down to zero, it has never budged off it. This is also when all lights, messages started.
  • Using an OBDLink LX, I've read only the P203E code. It cleared the current P203E code, but did not delete the permanent P203E code. Web says this means "Reductant level sensor - circuit intermittent/erratic", although it has never been erratic on the needle... just dead zero.
  • The gauge cluster on startup shows now, "Engine Will Not Restart in 750 mi Refill DEF". Since the original message at 1200 miles, I had at least 5 gallons in it. It currently has 2.5 gallons fresh Platinum as of last week.
  • Yellow idiot light with rain drops, blowing cloud, left of Park designator.
  • I've never seen any other error codes nor different messages on startup.
I imagine that Canadian repair would be my first choice. Unfortunately, the price is up to $755 and it does not allow me to change the address to a US address. I don't know if that means they won't ship here or what or it'll be more $$$$! They're obviously charging what the market will bare.
by using the relay jump trick until fixed , the regens will happen normally even after reaching the zero miles to no start .
This is good news. A little strapped at the moment, $3600+ for the dealer is a non-starter. I was most concerned that it would not inject if the computer is reading zero and it would eventually clog up like a gasoline car cat.
I've started to read that PDF several times when I saw it posted before, but always stopped since it didn't apply to my 2017. Thank you for mentioning that there still might be value... if I just read on. I'll study that now.
Thanks.
Also,
I've read about the crystals at the injector, but I thought that would throw a different code. Considering my truck only has 33K miles on it and I have a GDE street-legal tune, I haven't taken that apart.
You are confusing me
Pretty sure I read in other thread that you wrote
‘’ Pre EPA’’ gde tune , here you say street legal ,
Do you have pre Epa or epa compliant GDE tune
Apologies... I'm not sure how to name it. I got the tune before GDE went silent during the EPA witch hunts (June 2019). It was supposedly their street legal version (not the "Off-Road") version at that time. I have no idea about its legality now.
The other aspect... I have not taken off the DEF injector to see if it is clogged as I thought the code for that was different than P203E. Are there any more definitive symptoms than the ones above for me to check to confirm its the depth sensor?
Thanks.
OK , you got the "GDE Hot Tune (Pre-EPA ban) tune " ( it's the best for your engine's longevity )
only bad thing about it is that GDE cannot discuss anything with you about that tune ,
but it's OK you found this site with many trustable members (y)
Do you know the date when that tune was sent out by GDE ,
at first GDE had not figured out the new different software of the 2017 and
the DEF system was not activated , so the system did not inject DEF before the early june version .
2017 and 2018 DEF
As of early June 2018 , DEF system is active with the hot tune on 2017 and 2018 Models
see post # 30 to # 38 in this thread :
http://www.ram1500diesel.com/forum/...forum/ram-1500-diesel-tuning/57314-my-gde-hot-tune-impression-2.html#post891312
the DEF system was not activated .
2017 and 2018 DEF
As of early June 2018 , DEF system is active with the hot tune on 2017 and newer Models
see post # 30 in this thread :
Great to know (best engine longevity) and about the forum members. I'm feeling that it is my only resource for accurate information biased toward the owner. I did contact GDE last year and the response was very thorough as usual, but it did sound like the party line about my options. I don't like the idea of taking it to the dealer as I'm sure it'll get wiped instantly because of the outstanding recalls.
My receipt was dated June 8th, 2019. Shipped the 10th. Reading that post, I'm sure the DEF is being used as it did go down from its last fill up (after the Tune).
Thanks for all your help on the forum! I see you everywhere. :cool:
Maybe find a used ECM , stock tune , and withAlfa OBD flash your ViN and injector codes to it ,
lot less expensive than a tuned one ,
that would become your module for dealer visits , let them flash whatever they want to it .
usefull too , the stock tune with the reluctor ring correction can keep you going if the reluctor ring breaks ,
the GDE Hot Tune does not have that bit of codes (( to switch from crankshaft position sensor to
camshaft position sensor in case of failure )) that FCA/ Mopar/Stellantis was pushed to invent after
the NHTSA forced them to do something about the " leaving you stranded " possibility .
June 2019 , wow , GDE were improoving their Hot tune all the time , so many versions
since the first ones sold for 2014 , only they know how many versions , everytime they improoved
the Hot tune , every module they from that day , were including latest improovemnt , you got one of the latest
with all improovements . (y)
Yeah , it has become an addiction , I started with 1 hour a day on the site in 2015
to learn about my new Truck ,,,retirement permitting that ...
2017 and 2018 DEF
Would GDE not knowing how to activate the DEF cause the guage to read full after putting a preban tune in? Even though it was almost half way. And does that also mean the DEF is off?
If you have a 2017 early GDE Hot Tune before june 2018 ,
GDE had not figured all the parameters of the new different stock tune for 2017s
