Post here guys!
OBD Fusion is similar to Torque but for Apple. You can't use a Bluetooth OBD2 reader, you use a WiFi version, Scantool offers one.Is there an apple version of this?
As Crash68 said, OBD Fusion app works with Apple. I've been using the OBD Fusion app and Veepeak WIFI scanner https://www.amazon.ca/Veepeak-Scanner-Diagnostic-Adapter-Trouble/dp/B00WPW6BAE for a couple months now and they work great together.Is there an apple version of this?
Thanks guys.As Crash68 said, OBD Fusion app works with Apple. I've been using the OBD Fusion app and Veepeak WIFI scanner https://www.amazon.ca/Veepeak-Scanner-Diagnostic-Adapter-Trouble/dp/B00WPW6BAE for a couple months now and they work great together.
If you didn't ask, then it becomes stupid.Stupid question...with the WIFI scanner, do you have to buy a wifi service or is just the standard data package (unlimited) i have on my phone good enough? Iphone 6 on AT&T.
Will it display EGT, boost pressure, vacuum, etc?
You don't need any data... the scanner just sends the signal in WIFI. The instructions come with the scanner and the set up is very easy. Just make sure to set it up as a static IP, as in the instructions or you can't use anything else on the phone at the same time.Thanks guys.
I am talking to one of the Mods to figure out the best way to do it. That is an excellent idea.Could a generous soul please post a summary of useful pid's and settings as a new thread please? It would save a ton of time learning/searching for those of us getting started. If someone doesn't beat me to it, I'll try to come up with one as I learn it.
Think we could sticky a master list at the top of this thread for reference...I am talking to one of the Mods to figure out the best way to do it. That is an excellent idea.
If someone wants to work on it, go ahead. I won't be able to get it done today. I was going to go through the entire thread, make a list in Google Docs, and then copy it for an Admin/Mod to post a sticky with probably a PDF printout for people to take to their trucks for reference. I may not get it done until after the weekend.Think we could sticky a master list at the top of this thread for reference...![]()
It depends on what you want to monitor. Fusion has some nice PID's already, but you can't monitor things like DPF %, EGT1 and a few others without custom PID's...which are very easy to make by the way and you can find all the info you should need on here and a couple of other threads...I bought OBD Fusion for my Iphone and it has a ton of SAE PID's to choose from. With them I might not have to customize the entire app.
I updated my OBD fusion app recently and they added a bunch more built in SAE PID's! All the intake air temps, all EGTs, Cooler temps. DPF pressures,type,active, normalized trigger of DPF. Nox info. And a bunch more. I spent a ton of time imputing all the custom PIDs but that is not necessary now. Wish this came out a little sooner would have saved me a bunch of time.It depends on what you want to monitor. Fusion has some nice PID's already, but you can't monitor things like DPF %, EGT1 and a few others without custom PID's...which are very easy to make by the way and you can find all the info you should need on here and a couple of other threads...
Thanks for the heads up, didn't know they add they added all of those. I'll have to look into the update. I agree it would have been nice if they came up with those sooner, I spent a lot of time getting all of the custom PID's set up.I updated my OBD fusion app recently and they added a bunch more built in SAE PID's! All the intake air temps, all EGTs, Cooler temps. DPF pressures,type,active, normalized trigger of DPF. Nox info. And a bunch more. I spent a ton of time imputing all the custom PIDs but that is not necessary now. Wish this came out a little sooner would have saved me a bunch of time.
Oh man, thanks to contributors of this thread. 0 regens in 11,500 miles - just the smell and ticking when parked. Finally saw it hit 100% with a PID mentioned, watched egt III skyrocket, then all settle down 12 minutes later. Good stuff. And speedometer correction for oversized tires done too on app
Looks like hillbilli has a good list for the sticky.Think we could sticky a master list at the top of this thread for reference...![]()
