61 - 80 of 127 Posts
Just an update for my truck. Since my last post I had P026C popping up and clearing itself 3-4 times. Code always comes up when I am driving uphill. I never went to the dealer. I think they just charging money and not doing anything much. I am thinking on ordering GDE and doing the same as mikeyoung did, cleaning EGR tube and MAP sensor.
I hope this is final update. I installed full delete (EGR cooler is still present but there is a plate installed downstream of EGR cooler to prevent anything getting through EGR), and after 6000 km (~4000 miles) no codes have appeared. I noticed slight drivability improvement and better mileage. Temperatures are more stable during long highway drives. When installing delete, guys noticed a lot of soot downstream of EGR cooler. I have not cleaned MAP sensor etc.
Hello, I have the 2015 EcoDiesel also have just bought it about a year ago and I am having that same problem with horrible lag on acceleration especially after just starting the vehicle, and it did seem to get worse a little after I just had a software update last month. I am also not getting the engine code P026C, (Fuel Injection Quantity Lower than Expected). Does anyone here have any good idea what is the fix to correct these issues. I have taken my truck to the local Dodge dealership 4 different days over a 2 week period for them to troubleshoot the trouble code only and they have no idea what is causing it yet after 2 weeks. Then I drove from Kansas City to Arkansas for a trip and the code cleared. Then after about a month back at home driving an hour back and forth to work, then code has popped back up again. Appreciate any help anyone con provide!
I also did the FCA software update for the class action suit settlement about a month ago. Now I am getting the P026C code. Could the two be related?
My mechanic there is a technical service bulletin (TSB) regarding this code and wants to spend an hour or two checking out the various system the TSB indicates should be checked. This includes fuel filter, air filter, O2 sensor. I'm not too keen on taking this vehicle to the dealer as they charge $140/hour for a "diesel" mechanic and I'm more confident in my local guy.
I've got about 31,000 miles on the truck.
Here’s an update. The CEL stayed on for a few days and about 150 miles. On my last trip of 40 highway miles I made a point of stomping the accelerator and running high revs. One start after that and voila, the CEL was off. Hope it stays off because it sounds like it’s been fooling a lot of dealer mechanics trying to track it down. For safe measure, am changing out the fuel and air filters which are due anyway.
2 months has gone by and am still clear of the CEL. Am still making a point of stomping the accelerator from time to time on the highway. Does anyone else think this is a reasonable way to clear out the fuel injectors?
Errrmmmm... Probably not. I have never stomped on a diesel to "clear the injectors", and I have a fair amount of time behind diesel engines.
Just went through this for 4 months with everything from injectors to fuel pressure reg changed. Dealership finally changed the turbo boost pressure sensor and they say the truck has been fixed and is running good. going to find out in a few days. Turbo underboost is the main culprit with the P0296c code tricking them i think is whats happening. I thought it was egr valve but now there is a recall so finally that will get fixed
https://www.nhtsa.gov/recalls?nhtsaId=19V757
Ok, heres my situation. I had the code p026c.It ended up at the dealer five times and over a month and a half total days in the shop.. They replaced the injectors, rails,fuel pumps, fuel filter, drained the tank, all seals, oxygen sensor and finally the scr catalyst, now the truck is fine and mileage is up considerably.
So, in other words, you got a new engine ;)
Just got a service engine light on my Eco. I put a code reader on it and its throwing code P026C. I found some sketchy info on the net that says Fuel Injection Quantity- quantity lower than expected. Last oil change at 11500 I changed the fuel filter I know have 19000 on it. Has anyone ran into this? Is this possibly a fuel filter change or injector issues? Thanks in advanced.
I'm in the middle of all this bs right now as we speak. (2015 Ecodiesel Big Horn crew cab 54,000 miles)They hey have had my truck for 6 weeks. They changed the turbo, fuel lines, and fuel filter. A week later the code came back. Mind you the truck has been riding great for the last 5 years with no issues. Now they tell me they are doing a fuel sample and found the fuel was bad. They said this was not covered by my warranty and I need to replace my fuel pump, fuel injectors, drain all the diesel fuel and flush the whole system. Remember the truck still has no issues running just this P026C idiot light. So I had to turn it into my insurance company for the 7000.00 repair. Now waiting on financing company to sign the check, it's been a week so far and the Dodge dealer won't release my truck until they get paid. Unfreaking believable. This is my first and last diesel and first and last Dodge. Happy 4th of July. Still going to buy America just not a Dodge.
Sir DEW there were a lot of dealers who played the " bad fuel " card ,
it was a lie .
this could cost you $15,000 , dealer = Stealer....
here is just one exemple :
it was a lie .
Yes I have read many threads about the "bad fuel". The biggest thing that screws me up is that there's was nothing wrong with the truck except the P026C fault code. It ran great. It ran better better before they did the emissions computer update but still ran great. Thanks for the follow up Kazimodo.
Now I A non running 2014 with 92,900 miles. Looks like I will be continuing this thread in the near future. I will try and document this saga as it goes on. Hope everything is covered under warranty...
Hi Folks,
I still have this P206C MIL code on my 2014. It has been about a year now and when I have brought it in they have replaced something under warranty and after a few days it comes back on. Each service visit requires me to leave my truck for a minimum of two working days and it becomes a real pain as I need my truck on the ranch on a daily basis. Anyhow, I am getting ready to bring back in sometime this month to give them another go at fixing it.
I am trying to do some research in advance to communicate with my servicing dealer and FCA star so when I do get back in they can have parts on hand and give it some higher priority in the service department to get it done as quick as possible so I can go back to work.
Today I was looking at my Torque Pro app to see if it could diagnose the root cause. I have attached a screen shot of my truck at idle but I really have no idea on what all those values mean. I was hoping maybe some of you that also monitor your vehicle with a similar app or tool could compare my values with your own.
There is also a test mode on Torque so I ran it and this is what I got back:
Mode $06 report generated by Torque for Android
Vehicle VIN:
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: 68306455AC
NXSBD0022412510
Test report:
MID:$01 TID:$81
- O2 Bank 1 Sensor 1
Max: 16.9798% Min: 5.47987%
Test result value: 11.58997%
PASS
MID:$01 TID:$82
Max: 27.1979% Min: 14.59924%
Test result value: 19.3802%
PASS
MID:$01 TID:$83
Max: 3S Min: 0S
Test result value: 0.7S
PASS
MID:$01 TID:$9c
Max: 1.8S Min: 0S
PASS
MID:$01 TID:$9d
Max: 4.3S Min: 0S
Test result value: 1.4S
PASS
MID:$02 TID:$84
- O2 Bank 1 Sensor 2
Max: 1.99958 Min: -9.99424
Test result value: -0.11803
PASS
MID:$02 TID:$85
Max: 9.99393 Min: -0.49989
Test result value: 0.08509
PASS
MID:$02 TID:$86
Max: 6S Min: 0S
Test result value: 0.5S
PASS
MID:$02 TID:$88
Max: 50 Min: 32,768
Test result value: 7
FAIL
MID:$02 TID:$89
Max: 32,767 Min: 65,486
FAIL
MID:$03 TID:$8a
- O2 Bank 1 Sensor 3
Max: 655.34998% Min: 100%
Test result value: 327.66998%
PASS
MID:$03 TID:$8b
Max: 500 Min: 0
PASS
MID:$04 TID:$8c
- O2 Bank 1 Sensor 4
Max: 32,767 Min: 2
Test result value: 17
PASS
MID:$04 TID:$8e
Max: 50 Min: 32,768
FAIL
MID:$04 TID:$8f
FAIL
MID:$21 TID:$90
- Catalyst Monitor Bank 1
Max: 19.98817 Min: 0.8299
Test result value: 0.91805
PASS
MID:$31 TID:$91
- EGR Monitor Bank 1
Max: 6% Min: -327.67999%
Test result value: 0.16%
PASS
MID:$31 TID:$92
Max: 9% Min: -327.67999%
Test result value: 0.31%
PASS
MID:$31 TID:$93
Max: 19.98817 Min: 0.59993
Test result value: 0.80764
PASS
There is a total of 4 failures in the test harness. I have no clue as to how they could be related to my P026C code, if at all. What do you folks think?
Below is a screenshot from my torque pro app.
I just had a regen two days ago, but torque still reports it as 100% full. I do not know what DPF AVGF or DPF AVGT are. How do my values compare to your own?
Thanks in advance for your effort and help.
  • DTC P0171-00 System Too Lean (Bank 1) has now changed to P026C-00 Fuel Injection Quantity Lower Than Expected.
  • DTC P0172-00 System Too Rich (Bank 1) has now changed to P026D-00 Fuel Injection Quantity Higher Than Expected
